Check if the input shaft is seeping oil.
I would be inclined to replace the input shaft seal anyhow as it is only a couple of dollars ( from memory :cheers: ) and no doubt will save you the stress of seeing oil drops under your car 6months to 1year down the track.
Look at the mess mine made.
It wasn't even dripping much oil. Only a small drop every blue moon or so.
When reinstalling the input shaft with its new input shaft seal, be sure to replace the shim that is located inbetween the cover and the layshaft bearings casing. Tip the gearbox back as you slide on the cover so it doesn't slip out.
The layshaft bearing is the bearing next to the input shaft. The inputshaft is obviously the big arsed shaft exiting the gearbox. :rofl:
I've attached pics to help you know exactly what I am rambling on about. :)
https://www.sau.com.au/forums/topic/67559-clutch-on-r32/#findComment-1254563
  • 4 weeks later...
Well i did get my clutch in finally. I got from fro xtreme clutches in adelade. had a few problems at first with the wrong wrong clutch plate been sent to me, it wouldnt fit on the spline so i sent my old one down there and they matched it up. new clutch is very bitey indeed! Cant wait to take it to WSID and launch it for a 1/4!
https://www.sau.com.au/forums/topic/67559-clutch-on-r32/#findComment-1296516
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
