anyone had this expereince with there skyline.i have had this steering shimmy through my steering wheel at 100-110khm.i have replaced caster rod bushes and also had one wheel allighnment and two wheel balances on front wheels also i have levered and check for play in balljoints etc also had a look at steer rack bushes i found a bit of movement in them so i brought some aftermarket bushes they are whiteline they looked the same except the original bushes had rubber moulded around steel band and whiteline bushes were straight out rubber the guy said that they are for r33 but same for r34,anyway i installed bushes and tested for movement found it to be the same is this movement normal to skyline it moves aproximately 3mm from left to right or are the bushes different from r33 to r34,the bushes that were orginally fitted on right side on rack is a two piece rubber coated steel bush on left side just rubber ring,by the way the shimmy still very much there. hope some one can answer my question
https://www.sau.com.au/forums/topic/67601-r34-steering-shimmy/
they are about half worn but dont want to replace them as yet as i want to get 18" rims with 235 on rear and 225 on front cost about $2000 to do so saveing up at moment but hate the shimmy as it affects handling and lane changing at 100 khm .the other thing im suspect is the offset of the rims ive got but dont quite no how to measure this to find out does any body no how to do this.
I had the same prob on my GTt. The only thing that fixed it was Hub locaters. To save money, most wheel makers dont change hub sizes they just change stud patterns on their wheels to fit differant cars. Hub locaters are just plastic inserts you knock in the back of your wheel. This leaves no gap between the wheel and hub.
One thing to note though. If you have been driving with that shudder for a while you will probably need to get new tires. The problem stayed with me untill I got new rubber as well as the hub locaters. I think the shudder sends the tire out of shape.
This may not be your problem but it worked for me.
Craig
It has been my experience that speed related vibration is nearly always a balance problem. Have you had the tyre balance checked on the car? That will determin if it's a fitting problem, it will also eliminate other out of balance items like brake rotors. It may also be worthwhile trying the rear wheels on the front, even if it is only for a short drive down the highway.
I have noticed a tendency lately for tyre shops to only balance to the outside of the rim. I always have mine balanced inside and outside. Some brands of tyre are well known for having this problem.
Hope that is of some help:cheers:
    • Here's a boring history lesson on number plates People want illegal spacing to make their plate more readable, if mine was J2X BK, anyone who knows about the car would see that its spelling JZX. Years ago third party plate manufacturers could alter the text to make it look like something else, nowadays the computer software is locks that ability (well, ours does at work) Up until 2001 the first letter of a number plate represented the year of the vehicle, for example A would be 1983. (pre 1983, the format was backwards, so the year letter was on the end). Followed by 3 random numbers and 3 random letters. Things started to get complicated at the end of the 90s where T and V were 1999, W and X were 2000 and Y was early 2001. From 2001 they introduced a new 'layout' where the first two characters are letters, this represented where that vehicle was first registered in the country. The letters corrosponded to a region in the country. Some regions had a large number of codes, where as some only had a couple (despite being large in physical land size) Next are 2 numbers to indicate 2000s. So it went from: Y (March 1999 > Aug 2000) 51 (Sept 2001 > Feb 2002) 02 (March 2002 > Aug 2002) 52 (Sept 2002 > Feb 2003) etc etc When the 2010s got here, the numbers changed again, going up by tens 10 (March 2010 > Aug 2010) 60 (Sept 2010 > Feb 2011) When the 2020s arrived it went to 20 (March 2020 > Aug 2020) 70 (Sept 2020 > Feb 2021) etc As for personalised plates, you're not allowed a registration that makes the vehicle look newer. Take my 110 for example, its a 2004 car so I can have any available plate upto 04. I can't have a 54 because it was manufactured in August 2004. Which allows me to have a J plate, because its older (if that makes sense)
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
