Price: $10,000
Kilometres: 110,000km
Colour: Gunmetal grey/Needs respray
Transmission: 5 speed manual
Rego Expires: October/November 2005
Features: 18" Roh Drift R's, Alarm/imobiliser, Brass clutch, Hicas lock kit, spares avaliable
Pictures: Will be posted by sunday
Problems/Repairs: Car needs a respray, right rear quater needs repair after a hit and run, needs a new battery stand in boot
Reason for sale: Purchased a Mazda 808 and need to make room, also lost interest in finishing the car off
https://www.sau.com.au/forums/topic/67612-1993-r33-gtst-10000/
So it's been in a front ender as well?
The car was hit on the drivers rear quater by a towbar and thats shown in the picture. THATS ALL, no front end collision anyone who comes to look at the car will be able to tell this. The reason for the different coloured front end is because it had a bodykit which is now removed and i needed to buy stock bonnet and front bar, and white and silver is what i could get.
Any questions dont hesitate to pm.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
