Hi Everyone,
I Have A Pair Of Brand New Nismo Clear Indicators, I Bought Them And I Could Not Return Them.
They Suit A Bcnr33 And 34, Whih Is A R33 And R34 Gtr.
I Would Either Like To Sell Them Or Swap Them For R33 Gtst Clear Side Indicators. If Not I Am After $80, I Am Located In Sydney.
Thanks
https://www.sau.com.au/forums/topic/67784-nismo-clear-side-indicators/
