  • Replies 104
Thanks Rev and Aw11
Im not sure whether i need those pineapples as im not getting the diff bounce the other cars are getting...oddly enough this time i managed a 2.23 60 foot.
What i do need is one of them 5Giken twinplate clutches paired with a lightened flywheel!....And a maybe 17psi
Originally posted by macka
Thanks Rev and Aw11
2.23 is still not a world beating launch mate even I managed a 2.1 on el'crapo 205's (didn't make the most of it cause the vacume line popped).
Have you installed the pineapples yet? Reducing diff bounce isn't the major reason you put pineapples on, wheel spin is.
BTW whats was the terminal speed, 660ft and speed and 1000ft time?
Yeah i understand what u mean but last time i couldnt manage any better than 2.5 60 foot
Elapsed time 12.988
Terminal sp    113.35mph
60    2.25
330  5.79
660  8.59
1000 10.98
113.35mph Damn!
That mph is fat enough to get the low 12's on street rubber, get yourself a 1.9 or 1.8 60ft and bingo!
You must have a nice mid range power band dispite the lowish top end power figure.
If you still have the top secret ecu for next time you could run a bit of toluene in the tank to get a jap like octane level and stop the timing retard.
Explain toluene i thought it was cheap fuel?
I raced with 104 Nulon in it to be safe.
How do the bosch pumps go with toluene in it?
Well in my eyes i have a crap mid figure, i lost something like 20HP@wh when we retarded timing back from 20 to 15 degrees at 10psi
Go the pineapples still?
Macka,
Toluene is the cheapest form of octane booster around, Service stations often used it in there fuels as it has not excise placed on it by the government. There was an article on octane boosters in an HPI I have so if you want to know more then I'll look it up.
Octane boosters are cool as you will be able to advance the timinig without causing the engine to ping, but if you use it often it will f#@% your spark plugs.
See'ya :burnout:
Toluene is THE best basis for a turbo fuel full stop.
Toluene was used during the 'turbo era' of formula 1. Back when they were running 5bars(73psi) of boost in qualiying and 4bars(59psi) in race!
The formula 1 fuels were limited to 102 RON so 84% toluene and 16%n-heptane (has no octane rating to bring it back to 102).
Toluene has a RON of 122 but more importantly the RM/2 is 114 which is freakin high.
A 30% mixture of Toluene with BP98 yeilds a RON of 106 but huge RM/2 of 103!!!
The main disadvantage of running too high a mix of Toluene is the cold start and low rpm operation if you don't adjust the maps and timing. Having said that I have sucessfully ran the above mixture of 25/30% in my car with only the factory ecu and I didn't bother changing the timing either.
If you want some the Makit hardware store next to marlows balcatta has some, diggers brand 1 and 4L tins.
Go the pineapples! :(
Rev210,
Looks like you've been doing your homework, I read in an article that it will add about 2.5RON in a resonably safe mix, but is it going to be an advantage if you don't advance your timing? I thought the higher octance rating allows you to advance the timing safely, without pinging, but if you don't advance the timing will it make a difference to the performance?
Thanks for the info.
See'ya:burnout:
Adam32,
I agree totally, I was only suggesting that toluene was a cheap octance booster, and would only really be using it for the drags, the extra cost of adding octance booster during daily driving would be pretty substantial.
Macka,
I think you can get enough toluene to boost 100litres of PULP to 101.3RON for about $48, I have the suggested mix in a magazine I read last night, once I get home I'll post the info.
See'ya:burnout:
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
