My brain fart was when i had tried a remapped ecu and it sucked big time then i put my original ecu back in and when i was tightening up the harness with the bolt the bolt snapped and the harness was stuck on
  • Replies 41
I decided it would be a plenty easy job to replace the stuffed lifters in my old 308. I forgot to soak them in oil first, and second I read the book where it says to torque the bolts holding the rocker gear in a particular sequence which I ignored.
Started it back up and farted and ticked away like a bitch. Took all the bits off and did the torquing properly which only helped a little bit.
It took a month of driving it around before it regained its original power.
my mates RX7 had a hidden kill switch that we did not know about, the fog light button hadbeen changed over to kill the fuel pump when it was flicked.
Anyway, one day i was sitting in the car and got bored so i decided to start playing with stuff and i ended up flicking this switch and flicked it back again. After basically pulling everything apart we found the fuel pump was not working but notbeing able to find the problem we gave up and left the car there for the weekend.
Come monday we got the auto electriction in and after ****ing round with the car for a few hours we were going to wire the tail lights to the fuel pump so we could drive it to his workshop when i noticed that there was some white paint on the foglight switch. after pulling the switch out i found the kill switch leads and joined them together tocomplete the circut.
What had happened was that because the switch had not been used in so long the terminal had corroded so that even though the switch was in the "on" posotion there was no current flowing through.
All because i decided to play with the switch.
U snapped the aerial off another car because u were stupid enough to lock your keys in the car?!!??? ure a real tool buddy, i wouldnt admit to something like that if i did it thats for sure. Maybe that y ure girl dumped u :(
Had an oil leak a while back and didnt know where it was coming from, spent ages getting the whole car off the ground with bricks and wood and stuff so i could get under it started pulling stuff off left right and centre to get to gaskets and what not when i realised the sump plug wasnt done up from the recent oil change :Oops:
Well the thread was about "the absolute dumbest thing you've ever done to / with / relating to your car?" right??? I'm not proud of what i did and wouldn't do it again, but come on now it was sitting there running in the streets of Parramatta!
By the way i got back together with the girl but then she got deported.
Well I had a severe knocking and vibration coming from the rear left of my car. After driving around for a few days it progressively got worse and worse.....spoke to a few people and thought that either CV or Diff was going. Organised a rental car so I could get to work while my car was being repaired and in the meantime called my uncle who is a mobile mechanic to take a quick look at it and help confirm the issue.
Anyway....he jacks up the rear left wheel off the ground and wiggles it.....FARKKEN wheel nuts were loose to the point where the wheel was knocking around against them.....uncle tightened all my wheelnuts for me and I stood there looking like an IDIOT......
Had to try and cancel the rental car which the girl was kind enough to let me do without losing my $100 deposit.
But i learnt something very important that day.
had a 95 model charade and one time in the afternoon after topping the radiator up with coolant, i closed the bonnet...but it wasnt shut.
mate called needed me over in a hurry, i jumped in took off no realising my bonnet wasnt closed properly and WAMM, at 60km/h the bonnet flung up and hit my windscreen and stayed there, i pulled over and started punched the dents out of the bonnet and then it wouldnt close proprly because the hinges were buckled.....
haha
A guy from my tafe went out to help a mobile mechanic one day to help with a service. It required an oil change and a change of spark plugs. The mechanic asked him to fill the oil back up in the car. "Hey this car only take 1 litre of oil" The mechanic turned around and he had filled one of the spark plug holes up completely up oil... Lol dumbass
when lowering my car did the wheels up kinda tightish whilst still in the air, lowered her back down and forgot to tighten then further, alas on the way to sydney the next day a severe rattling on the freeway at about 140, pulled into a servo cause i don't have a tyre brace, 3 nuts fell off as soon as i touched em, another 6 were so loose it wasn't funny, woulda been absolute disaster if a wheel had fallen off, haven't forgotten to tighten them ever again
That's right, whats the absolute dumbest thing you've ever done to / with / relating to your car??? I thought i'd start this thread and get everyone to share their efforts after quite possibly the biggest display of supidity, by me...ever, on Saturday, here goes..
My mate and I were installing his old Sony head unit in my R32. So we got all the tools out, unplugged the battery, took the dash surround off etc, put it all back together and then tested the deck - sweet, it worked, no worries.
Went to start the car to move it...it turned over but nothing, try again - same thing. I waited another minute, tried again but it still wouldn't fire. Checked the battery connections, tried again, nothing!!! I'm freakin out about now cos I got my car all tuned etc the previous day at UAS so all should be fine...i couldn't believe it, I had to call the NRMA cos I had no idea!!! I was told 90 mins...great, had to wait...thankfully they rocked up after only 10mins. I started telling the bloke what the problem was then he asked me if i had an immobiliser...FAAAAAAAARK!!!!  :bs!: So i hit the unlock button - "beep beep" it, turned the key..VAAROOM!!! MOTHERF**KER The poor NRMA dude didn't
even touch my car!!!
Now i'm never one to be too ashamed to call the NRMA but i think this one was bordering on the ridiculous!!!
Went and got rid my classic big block ford powered 68 ute and jumped into one of these SH%$box Skylines
in my commy after putting the new motor in i went to do up the bolts for the intake...
big mistake
i hadnt put the dizzy back in place and one of the rear bolts fell straight through the dizzy hole.
i ended up having to pull out the motor and drop the sump to get to the bolt! :)
Two for me.....At work....have the keys in my car out front. Didn't realise the boss had locked the front door while we were having a beer so that people wouldn't steal stuff from us. Boss had left before us (half hour or so). We locked all the roller doors down and padlocked them. When it came time to exit the building...oh no...door is locked....my keys are in my car which is no more than 2 meters from us. Had to ring all the surrounding businesses, on a saturday no less, to find out if anyone could get them out and unlock our front door to let us out. We could have been stuck there all weekend.
This one is for my brother.....
He's having probs with his alternator. I fix his probs but he still has a stuffed battery. He forgets to get a jump start from his g/f before she leaves in the morning in their good car. He proceeds to roll the car down his very steep hill to clutch start it. No go. The microtec doesn't even have enough voltage to power up. he gets to the bottom where his car is in the middle of the road. He decides that he can't leave it there so he gets out and starts to push it back up onto the footpath. Anway, car starts to pick up speed (slight downhill decline) forgets that he has left his drivers door open and it collects the street sign and rips it clean off it's hinges.
Hahah, great story you had me laughing out loud. Keep them comming...
Two for me as well.
17 years old and I know ZERO about cars. I see a TA22 celica for sale and knock on the guys door. Wants $400 but it has mags so I dont give a shit and think its the ants pants. He takes it for a spin with me ( with the stereo blasting so I cant hear all the noises ) and he does a burnout and I nearly wet my pants with excitement. Run home get money and come back and buy it off him.
Get it to a mechanic for a RWC inspection and when I come back the mechanics are pissing themselves laughing as I have purchased the biggest lemon they have ever seen, bog everywhere, engine is nearly dead etc etc. The repair list was into the thousands of dollars and they told me to take it to the tip. Discouraged, I took it home where it sat in the backyard for months untill my parents wanted me to move it. The battery was flat, so I grabbed the one of my parents car to start it when I put the terminals on backwards and fried everything. Ended up getting picked up by a wrecker for $50.
That was 10 years ago but more recently had the good old car fight with the missus, you know, when they jump out of the car and you follow them at 10km/hr with the hazards on saying "can you please just get back in the car". Anyways, the stalking aint working so I get out to follow on foot. The obligatory "ok ok Im sorry blah blah " goes on and we return to the car and you guessed it the keys are inside and doors are locked. 10.00pm and nobody is around. Call on a mate for a favour who is at his fathers 50th birthday and he does me good and drives out to me with some tools and stuff approx. 45 minutes away. He gets out and goes to his boot and grabs his tool box and walks over to my drivers side. Looks at me blankly, turns around, and bumps my door with his ass and the lock pops up. It hadnt shut properley.
being a newbie in my first line back in 2003, driving in the wet at about 2am in the morning, raced a clubsport and was cruising in front of him and thort id show off, like how ma friend did in his turbo tx3 fwd not 4wd, any ways so i shift from second to 3rd at about 80km/h pop the clutch hard and turned the steering wheel, BIG mistake drifted the ass out didnt know what to do and ended up spinning into a gutter and just missing a pole!!! had to spend 600$ on a new lower controll arm on the right rear, cracked my side skirt alil, buckled my wheel which i had to drive around on for a month or so after i fixed it, learnt a big lesson after dat day:)
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
