Seen it today up close at the EC Powercruise.... Mmmm !!
Me and a mate were sitting at turn 1 watching cars on the dyno and we could hear it screaming up around turn 4, 5 and 6. Apparently their was some damage to the box tho?
Would have easily won todays 6 Cylinder Dyno Comp too by a country mile.
  • Replies 114
Making the car look like a 16yr olds gts-t was the last thing we wanted. It looks like a tough GTR minus the badging. Nothing more, nothing less.
Of course.. Anyone who knows their skylines can tell in two seconds its a GTR. Its the rest of the clueless general public that have no idea.. (which is basically everyone you see on the road who isnt in a skyline)
I'm just bitching about kids putting GTR kits on their cars, and polluting the image real GTR owners like you and I have. ;)
Theres nothing worse than pulling in somewhere in your GTR and some rotten kid coming up to you going "awww fully sick skyline man, how much did the body kit cost you? is that a real GTR?" :cheers:
You just have to drive down cavell at the gold coast for five minutes to see why the line between gts-ts with kits and real gtr's is becoming blurred in the general publics eye. Though it would be cool to see how much less or more attention you get by not having the GTR badge from the v8 bogans.
That said, those massive Volk Te37's look pretty intimidating :)
/rant over.
Guest two.06l
Stace - looks good :D  I think the front ride height needs to come down a bit though (or mayby mine is just too low! :D ) I'm not sold on the clear indicators...
That is some pretty impressive power you are producing!
The ride height is due to the DRAG SPEC suspension we are running, for normal road use HKS hyper dampers are normally in place. Power has increased to 467kw...WOW.
Guest two.06l
Yes Ben smashed 3rd gear coming up the rise out of turn 9.
BUT......
Fitted another box on Sat. to qualify for the dyno......to take second place in the finals and fourth overall.
Stace,
*embarassed*
After 3 months of wheel shopping for my r32 i've decided that te37's or lmgt4s are the only way to go!!
Those are gorgeous, did you buy them new? Who did you source them through? What size are they?
I post whore way too much to think before I press submit :D
Once my posts slow down you'll all know my car has finally arrived...
Guest two.06l
Stace,
*embarassed*
We got them from jimmi here on the forums, try j-plus for some more as he always has a good supply of rims coming in. They are 17x9...good for track use.
  • 1 month later...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
