This Group buy is for a hybrid copy intercooler size being 450 x 300 x 76mm. Need 5 people to register for the cooler to cost $280 + delivery($20). Cooler are here right now so once we get 5 people I can ship them off or you can pick it up.
HERE ARE THE SPECS.
Attrictive polished aluminum look
3" inlet and 3" outlet pipes for high flow
Low pressure drop 0.2psi at 15psi of boost
80 psi for up to 800 horses
Made by lightweight but strong material. Same Structure and material used as famous "Hibrid" Intercooler. Weight ~8kg
All coolers have been Pressure tested.
15 bars core design. For more efficient air flow over the older 16 bar design.
PACKAGING
As seen in the picture the cardboard box has polystyrene strips to protect the fins from transport damage. The cardboard box is even double up in places for extra strength.
PAYMENT
Payment must be by Direct Deposit.
Local Pickup is available. Save postage
Registered Interests
1) Predator
2)
3)
4)
5)
FAQ
$5 per cooler will be donated to SAU
https://www.sau.com.au/forums/topic/68130-intercooler-450mm-x-300mm-x-76mm/
I'm definitely in, as I just sold my larger one..
These are a great fit for R32 guys, without having to go as crazy cutting the bumper to hell and back like with the wider one.
flex: This item is for the intercooler only...you can get piping kit from car performace stores. I will be able to do piping kit in the near future sometime - not quite sure when though.
GTR 94: I will be lying if I try an answer this question. :rofl: Anyone know?
MJKAPC.. I've measured it, and the 450x300x75 cooler is that much better for fitting under an R32 gts-t with stock front bar.. compared to the extra 20cm of the larger one that many people have (and cut to crap front bars)
You will still have to cut the bottom of the bar a little.. but you shouldn't have to cut the main bumper support due to the width, which you would for the larger one.
So I believe anyhow, that is should be a much better fit, and that's why I'm getting one ;) so buy one, and I can save $20 :cheers:
OK guys I have recieved your money. I tried to get the coolers on the weekend but he had no stock on him. He stores them in a warehouse somewhere. I was told I can pick them up today if I can get intouch I will drop down to pick them up tonight.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
