  • Replies 42
Yeah, in such a small vehicle, you've got zero road presence, and many drivers don't watch out for you.
I was looking at buying a peugot scooter before I got the line, but when I took one for a test drive and was nearly run over by a 4WD, I decided I needed something bigger ;)
i find it hard to believe they wouldnt have seen you jason.... :cheers:
It was exactly $2400..... or .... $600 more than my hand bag... humm.....
Yeah im already dealing with arseholes on the road... THey do see me.. because they make a pathetic attempt of overtaking me. Just a note to cars... they skim past me with about 1/2 a meter between the bike and their car, the speed they pass at just about pushes me off the scooter... Anyone overtaking a scooter please give them plenty of room. Its hard though fighting with the wind, than having to deal with unpaitent road rage morons! Maby i should get some weapons installed... Paint spray can as they go by?? would have a nice effect on the side of the car! or a screwdriver.. nice scratch!
but... yesterday a guy at work told me he wouldnt ever buy a moterbike because hes friend was in a serious accident while on his bike..... but... if your friend was in a serious accident corssing the road... would you never cross the road again?
Jason, I was actually going to get a peugot ludix, but it was $3000. I was going to save up and get one in a few months, but because of what happened with troys car... I figured i had better things to spend that extra bit on. Just changing the locks on the house cost us $300, which we get back from our content insurance but that will take them 3 weeks to process!
Just a note to cars...   they skim past me with about 1/2 a meter between the bike and their car, the speed they pass at just about pushes me off the scooter!
thats what paul n i do to pushbikes in peakhour traffic :P So annoying ..... least scooters and motorbikes and keep up the pace and are meant to be on the road!
Kyles - watch out for Perth drivers. I've been riding a motorbike for over 5 years now and I still nearly get run over at least once each time I'm out.. Perth drivers are inconsiderate and stupid/blind.. Just make sure you give yourself plenty of room to get some road "presence" and make sure you keep a close eye out for the traffic and you should be fine.
*cough* Yokel lanesplitter!
:D:)
*cough* perth driver *cough*
Nah - not while lanesplitting. Funny thing was, that during peak hour traffic I always found it was safer to split as people would always try to take up my spot in the lane *ignoring* the fact that I was there.
Farkin Perth drivers suck....
Scooters Rock.
I have a Beta Eikon - with an exhaust and Malossi MHR Brake Pads.
Does 90 on the flat - and the most wicked stoppies.
Have an uprated variator and clutch going in Weds.
We should have a scooter cruise...
Jash
Jash, should i take it to you to get mods?
I enquired about getting neons today. im doing it!!! Getting 2 each side inside the frount wheel gard, and 2 on the back wheel gard .. red... Ill have a switch at the frount. The guy at car sterio city even thinks he could install a sterio on it! ill do that when the scooter becomes a toy and just for leasurly drives in summer.
Ive also decided to get the wheels chromed. But dont know who does that.. anyone know?
what you need that for jash???
Belt around home on it. Handy for picking up takeaway. Also good for taking to town - free and easy parking. Plus its hilarious. Particularly when you pull stoppies at traffic lights.
Jash
and most importantly, try to anticipate what the other drivers are going to do. Can save a lot of trouble and skin. Unfortunately some of them don't even know themselves what they are going to do.
Jash
i didnt know vibrators could do that.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
