  • Replies 93
cat /dev/rnd > /dev/snd
I used linix for ages, though Debian (apt is the greatest loonix tool ever)...
Might install it on my old box as a "**** around" server, but I'd never go back to using it as a desktop.. Way too involved and time consuming trying to get everything windows-based to work :cheers:
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1267877
Yeah, well I was sick of windows crashing all the time and the 400 spyware/adware a month.
I don't think I can get spyware/adware anymore so that problem is solved. I still have a dual boot with XP running.
BTW, I still have a running copy of DOS 6.22, ALL Windows Versions, Redhat 7 and 9 and Fedora Core3.
you say....what the hell do you know about OS's
I'm the f$%ken OS MASTER.
Linux aint that bad. Especially this Fedora. It way outpowers windows in all ways and has less vulnerabilities. Plus I was being attacked by members of Andre NET every day. I had to run 4 firewalls just to stay alive. Now...no probs and I have a massive artilary at my disposal....so now I go to war.
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1268357
Are you new to computers?
1 x hardwire firewall/router
1 x XP install with personal firewall running and all non-essential services blocked (remember, DENY all and allow each port individually!)
1 x MS Anti Spyware
No problems.
Just use common sense. "Britneynaked.jpg..................pif" is still a pif. "Click here for free porn" is never free porn. Accepting files from people you dont know is stupid. Running an FTP/HTTP on common ports is asking to be pwned. Using MSN is asking to be pwned. Using IE in anything other than "Restriced Zones" is asking to be pwned. Etc.
For the casual hax0r, a loonix box with a default install is easier to hop into than a windows box :rofl: Hello plenty of installed services that are all open and left with default settings!
I'm interested to know how linux "outpowers" windows too, is this a tractor pulling contest? X Windows is slow and clunky and needs a 3Ghz machine to run anything more hardcore than KDE.
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1268502
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
