After spending all day Saturday at powercruise I have to say what an awesome event, it was great seeing Paul and Stace, Adrian and a few other SAU guys
I for one can't wait for next year and will be the first to enter :thumbsup:
Congrats to the Skyline people for having a go and doing imports proud
https://www.sau.com.au/forums/topic/68471-powercruise/
  • Replies 85
I saw a few of the guys out there on Friday I was with the red RX7 with gold FRs. The Friday was poorly organised, rules were very strictly enforced and not as good as we expected. I didn't go the rest of the weekend, but I've heard it was a hell of alot better!
Except for one Ferrari driver
https://www.sau.com.au/forums/topic/68471-powercruise/#findComment-1269738
I was also there on Friday and wasn't impressed at all with the organisation nor the marshalls' one-eyed view towards certain cars. Good to hear that things got better over the weekend.
What happened with this Ferrari? Pics? :)
https://www.sau.com.au/forums/topic/68471-powercruise/#findComment-1270195
I did the road trip and have to say it was well worth it.
The number of high quality and big dollar cars was much more than the previous 2 powercruises held in QLD, sorry Qlder's but it's true.
The program was on schedule if you were a Queenslander (laid back as usual) but alot of the sydneysiders were annoyed as things didnt run by NSW times. It wasn't the best time to have the event due to the royal easter show in syd, easternats in vic and cruisetime in qld all happening at the same time.
But at the end of the event I left grinning as I discovered some of the secrets of the VL "PSI" with the 712rwhp RB30DET :cheers:
https://www.sau.com.au/forums/topic/68471-powercruise/#findComment-1270310
Guest DIRTgarage
and guess who smashed the 712rwhp VL in the Street Racing event......owned!!!
no point having over 700bhp and not being able to use it. By the way thats a great photo showing how properly set-up drag suspension should work.
also ....Duncan i was always a circuit racer, so i should have an idea on cornering. Will have my first "real" go at drag racing on the 9th at Compak Attak.
https://www.sau.com.au/forums/topic/68471-powercruise/#findComment-1270370
What do ya know - the SAU representation at a circuit was made up entirely of drag racers...
You circuit types really couldn't organise a root in a brothel could ya?
I had a ball and I'm stoked that I now have a power figure for 2RISMO the dirty nitrous cheaterer.
And that should be, "The secrets of the 737hp VL, PSI." What a weapon.
Adrian
https://www.sau.com.au/forums/topic/68471-powercruise/#findComment-1270666
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
