friday arvo i put a mates S14 s2 rims on the front of my car(not std rims) 17 x 7.5 with stock 32gtst rims on the back,its been hell fun all weekend,but good chance i need a wheel alignment now but worth it!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
