I'm just wondering whether skylines lose a lot gettig from the flywheel to RWKW?
A stock R33 gtst Flywheel = 187kw
At the wheels = 140kw????
I saw an article in the latest motor/wheels magazine on VY SS and BA V8 falcon upgrades.
I think the SS stock was 245kw Flywheel and 221kw at the treads. After $1000 rechip it was 240RWKW and 1/4mile in about 12.8!!!!! and 0-100 in mid 5s
If these are the right figures then there is minilmal drivetrain losses with the holden compared to the skylines....
average stock rwkw 4 a R33 GTS-T would be roughly about 130kw depending on gearbox/age of vehicle etc.
yep of course the ss & ba have minimal drivetrain losses compared with the r33 skyline! they are brand new cars..r33's are between 8 & 12 years old this year :cheers:
the age/condition of a vehicle plays a big part when it comes 2 drivetrain losses
r33 rb25 losses through the drive train are about 60 to 65 kw, dont believe everything that you read in motor magazines. theres no way that a v8 losses only 20kws through their drive train! if anything they would loose more than a rb25. id say holden has paid of the magazine to talk it up!!
as an aside - as if motor isn't on holden's payroll
explain how a commodore / variant that pisses power steering fluid at the track makes a minor placing at PCOTY??
especially since HSV are 'track oriented' eg SV6000
/end rant/
I dont see why because they are brand new they would lose less. There is no major technology breakthrough in terms of gearbox/drivetrain.  Maybe they are talking it up!!!
So what u r saying is that a 1993 model stock R33 which was dynoed directly off the showroom floor back in 1993 would give the same figure as a 1993 model stock R33 which was dynoed in 2005? Interesting...
Maybe lose 5kw. A new engine will take about 10k -20k kms before it loosens up. In fact when I was working at ford even some of the other engineers thought the cars that had done 90k kms etc were quicker than the ones that were near new.
Most R33s would have more than this amount of kays and obviously older than AU falcons but I still reckon most of the good ones would be within 5-10kw of showroom spec
how can it do 1/4 mile in 12.8 and have a speed of 0 - 100 of mid 5's wtf , a r32 gtr is quoted at doing 0 - 100 in ~ 4.94 and have a 1/4 mile of 12.94
umm... tell me if im wrong but... different gearing, different touqe and a different power curve, different cars make the power at different rpm, cant compare cars guys, ones a v8 family car (lets face it) and the other is designed to get to the 400m as fast as possible. two cars designed for different reason. PS, I love my holdens, but motor is full of BS.
BUt yeah, stick the wot the guy asked For. Wots the stock RWHP of a R33 GTS
All manufacturers quote power at the flywheel, so the 225 Gen III's are in fact 225 at the flywheel not the wheels, just a point of reference.
And it is correct about drivetrain losses, it is also related to gearing and other factors such as fluids.
Here is a a post I prepared earlier, that a search found for me;
When you put a car on a chassis dyno (roller or hub style) there are power losses, in the gearbox, the tailshaft universals, the diff, the driveshaft universals, the wheel bearings, the tyres and the rollers themselves. In a 2wd Skyline (like na R33 GTST) this works out around 50-60 kw, based on the cars we have tested. A couple of which we have also run up on the engine dyno confirm this.
Obviously when you add a transfer case, front diff, front drive shaft universals, front tyres and the extra rollers you loose more power. Around 20-25 kw based on what we see with GTR's.
So if you have a 280 kw engine, it will show around 220 rwkw and 200 awkw.
I should point out that there are no "losses", Newtons law applies, "energy can neither be gained nor lost". So the 60 kw is not "lost" it is transformed into other types of energy, in the car's case that's generally heat.
Hope that is of some help :D
As you add more power to a engine do you lose more power or is it the same?
e.g. does 270rwkw car have 270kw + 60kw =330kw at flywheel or 26% lose 100/74*270=364kw at the flywheel?
Yes I guess you would loose more power as you add more engine power. You are putting more stress and adding more heat to the drivetrain.
As engine power increases, the drivetrain losses would increase to a point but not at anywhere near the same rate.
I think what SK was alluding to is that there is a certain amount of power the drivetrain will transform into heat and thats about it.
Using the "rule of thumb", an R33 GTST manual that cranked out say 800rwkw, using the 26% rule would have 1008kw at engine. Thats 208kw that would have to be transfered into heat. Now I'm out of my league in making any educated guess as to what the gearbox and diff temps would equate to but Im sure its damn hot.
The percentage rule seems to sell a lot of magazines though..........
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
