Hey guys,
I have a r33 RB20E
I'm getting 250kms per tank on ultimate, and 300kms per tank on optimax, just had new plugs, new oil, etc. I only rev out gears occasionally, and i cant seem to work out why my fuel economy is so damn bad!
Ive put up with it long enough, but now its past a joke!
I only live 5-10kms from school so it does do a fair few cold starts a week...
Can someone suggest how i can go about fixing this? and getting a bit more kms out of my tank, i dont have any complaints about the car bar that. I was thinking dyno tune, but what else is there?? and is this even possible with the stock ECU. Also, is there anything i can buy aftermarket to make the situation better? can i advance timing etc??
Thanks guys....
Dayne
https://www.sau.com.au/forums/topic/68699-fuel-problems/
hmm... 250-300 to the tank is quite poor.. specially in a 2L car...
I wud recommend maybe try resetting the ECU? (there are threads - try a search)
clean the afm? but yeah a dyno sounds like a good idea and will save u from mucking
around - check the AFRs and see how it goes.
keep us updated man.
https://www.sau.com.au/forums/topic/68699-fuel-problems/#findComment-1272861
Yeah, now i just need a few more things and it'll be sweet:)
Yeah its a series 1.5 R33 skyline with an Rb20E
Pretty strange i thought too, but it'll do for the time being, might even turbo it, but i dont think it'll be worth the hassles, just sell up and buy one already done!!
Thanks again for all your help!!
Anyone needs a new sensor, repco sell them i baught a ford EL one, got it for $85!
https://www.sau.com.au/forums/topic/68699-fuel-problems/#findComment-1275074
According to the following site. the RB20E r33 is a "GTS urban runner" or "GTS urban runner S" =)
and im no smart alik. i just stumbled upon this site.
Great site if you wanna know the basic details of all the different type skylines made. from 1989 - current. ENJOY!
http://imports.motortraders.net/imports/se...n&model=Skyline
https://www.sau.com.au/forums/topic/68699-fuel-problems/#findComment-1275560
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
