gday ppl
chasing some bits to finish off my r32
stock radiator
fan shroud
radiator pipes
2 x stock cooler pipes (one goes from turbo, other from x over pipe)
ballast resistor
and the bracket that holds the speedo drive into the gearbox.
thanks ppl.....brett
https://www.sau.com.au/forums/topic/68882-urgently-need-r32-gtst-bit-brisbane/
sigh.. i have the cooler pipes dude.. i will only sell them for a premium of $50, as i was going to use them in my piping setup.
either that or do you have anything r32 related worth swapping?
i might have these parts lined up now. i would prefer to get them all off the one person to save running around/paying for seperate freight. if i get stuck i will let you know.
cheers....brett
p.s if someone has everything i need can they pm me as its not certain yet i have all these bits.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
