yes i did search....
The only thread I found which was alot more help than the thing you linked was the following:
http://www.skylinesaustralia.com/forums/sh...sable+door+lock
did you read my question? -> nope!
What you've linked me to does NOT answer my question. I also have a series 2. Auto lock and unlock while driving is not a feature on series 2 cars. I even posted in that thread on the 3/10/2004. Gee... thanks for jumping to conclusions and branding me an idiot before you even read my question.
I am refering to the switch on the drivers door which you can lock and unlock the passenger door with.
Does anyone know of any other way of disabling this without "cutting the brown wire". Is there a fuse somewhere? Is cutting this wire the only thing that can be done to disable this switch?
Thankyou again.....
Hmm...I'm not sure how to do that.
Does anyone have a wiring diagram of the drivers door controls?
All I know is that the brown wire coming from there completes the circuit that unlocks the passenger door.
I've currently just shaped some plastic and stuck it either side of the switch.
can i ask why you want to disable it? just out of curiosity...
good luck getting it sorted.
I'm guessing it's due to the fact that someone almost had their car stolen recently and the switch in question was the method they were using to gain access (by feeding something through the window and hitting the switch to unlock the door)
what lazy-bastard said.
If you check it out it is actually really easy to hit the switch with a long, wide, thin metal object. In not very much time the passenger door would be open and nothing broken.
:rofl: well it will be good to find a secure way of doing it then... car thieves = ;)
can i ask why dont u just cut the wire?? i dont think its connected to a fuse as its only a relay to a door lock. you can still use the button to lock the passengers side door but it just wont unlock when u use it thats all. yeah i dont think the series 2 has the auto lock as my series 1.5 doesnt have it.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
