195rwhp.  Stock engine exaust etc.  Fuel reg, GTR (or similar) pump, stock dump then 3inch back, and about 12psi, stock cooler also.  :)  lightweight flywheel too, which would help rwhp figures.
cool man. i got 260rwhp with rb20 bottom/ rb25 top running 8psi. lot of internal work done
https://www.sau.com.au/forums/topic/69281-cefiro-power/#findComment-1282751
260...respectable...how's the torque...does it have any lag at all? im just curious
not too much lag actually. boost comes on pretty quickly. i'm lookin for a power fc for it cause i only have the stock computer re-maped and my boost controller isn't working properly. looking to boost it 20+ psi. cause 8 jst aint enough
https://www.sau.com.au/forums/topic/69281-cefiro-power/#findComment-1284250
271rwhp RB25, Hiflowed turbo with GT28 cartridge, 9psi, wolf3d, SX fuel reg, pod, custom turb manifold, 3" full zorst, 680x300x78 FMIC, oil cooler...
Need bigger injectors for more boost, so much of my turbos potential is wasted here, anyone got any suggestions on a good injector upgrade?
https://www.sau.com.au/forums/topic/69281-cefiro-power/#findComment-1290625
Also how do you find the wolf? Or more so the tuner?
https://www.sau.com.au/forums/topic/69281-cefiro-power/#findComment-1290702
I got the wolf of a user on this forum in the for sale section, it was in QLD, now it resides in NSW
It only got tuned 3 days ago, I found the tuner on the wolf website as one of the distributers - I was in a bit of a panic at first looking for tuners...
The car runs beautifully with the wolf in and tuned, with the exeption that it won't idle on a cold start but im sure thats just a tweak that needs adjusting and usually within 1 minute of driving its happy to idle at the first set of lights I hit.
I'll get that fixed up in the near future anyways.
https://www.sau.com.au/forums/topic/69281-cefiro-power/#findComment-1290873
Hi, my cefiro was just put on the dyno, its only putting out 124kw ATW, it has a RB20DET and a factory 5 speed, the only work that has been done to it is a Pod filter, 3inch exaust, GTR fuel pump and 0.7bar of boost (i think is stock)
https://www.sau.com.au/forums/topic/69281-cefiro-power/#findComment-1308730
mine makes 128 rwkw with a cat back exhaust and a GFB bleed valve on an RB20DET... hopefully soon I'll be able to fit a jaycar fuel adjuster, pulse controller and boost controller and get some better response... someday when I get time.
Till then I'm happy with the power the relatively stock car makes.
https://www.sau.com.au/forums/topic/69281-cefiro-power/#findComment-1317909
Just had mine @ XTC and it made 130rwkw with a stuffed exhaust baffle.
Got that fixed so apparently it is around the 150 mark with pod, 3 inch cat back, GFB bleed valve at 10psi.
Getting GTR cooler and 2530 soon.
really? that sounds like a lot of power for those mods? 150kw... I could understand a 130 with exhaust and a bit of boost but 150 seems a big jump in power after fixing a catback issue. you have the rb20det right?
https://www.sau.com.au/forums/topic/69281-cefiro-power/#findComment-1318336
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
