48 hour permits???
Guest GR33DyMANGO
hi guys. well my cars finally ready to be picked up from the compliance workshop:)
now i have to go and get a 48 hr permit so i can drive the car home. so what im wondering is whether i can just drive my car around anywhere for 48 hrs or only to specified places?
whats the deal with these permits? any help is much appreciated.
thank.
justin:)
https://www.sau.com.au/forums/topic/6945-48-hour-permits/
I thought you were only allowed to go to places to get work done to the car, but you can bullshit can't you?
"Yes officer I'm on my way to get the car tuned, honest."
GR33DyMANGO caught doing 210km/hr in a 60 zone at midnight Saturday night.
See'ya
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-102693
When you ring up they ask you what movements you need to make, home - workshop - pits - home etc.
You cant drive at night, all road rules apply, only you can drive the car and a few other things they tell you when you phone transport.
I think I needed to get these bloody things 4 or 5 times when I bought my car in:
docks to home
home to pick up comp. plates then home again
home to get comp. work done
comp. workshop to pits then home
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-102705
gr33dy, is yours the white R33 down at Global?
twas down there today getting my plate stamped on, your car looks nice n clean.
I then went to the pits and failed :) rear tint is too dark and the radius rod bush is leaking oil.. which is what a replaced when i busted up the front from an incident a while back but the piece is obviously faulty, it was second hand so i cant complain.
a new one goes on tonight, aswell as the tint off tomorrow and all should be cool.. *gulp*
Shaun
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-102921
Originally posted by Pva_Glue
cruising doesnt make you cool... it's how you drive your skyline make you cool.
does that make sense?
cheers
Joe
Quote: - From Instructor @ MC Motorsport on PVA
"That guy is an accident waiting to happen!......"
:) :) :):D:):rofl: :rofl: :rofl: :rofl: :rofl:
So....how does this cool thing work?
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-103001
Shaun
Hi Radium,
Nope, the white one with the GTR body kit is mine.. Got it detailed for $100, if anyone is interested. It was so filthy when it got off the boat .. I think it would have been better had I clean it after I got the car over the pit, but I just couldn't look at a dirty white car. :)
Bye
Richard.
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-103014
thank.
justin:)
Hey Justin,
I got the temp 48 hr permit last weekend and drove it around ... Went passed two or three police cars in town but no one pulled me over. Probably because I was moving like a snail :) ..
Bye
Richard.
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-103016
I got pulled over on the way from picking the car up from the trucking yard to home. The guy wasn't worried about the permit ... he didn't like how the front bar was sitting inside the car!
I also drove around the city without plates before I had rego. Cops drove past and didn't care :)
Maybe they see it all the time round the licensing centre.
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-103129
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
