Gday all,
A real quickie here, just wondering if anyone knows what power an RB20DET, pref out of an R32 GTST, makes at the wheels - when she's completely STOCK STANDARD...
I've just the below mods done to my baby and she now puts out a tidy 166.3 rwkw running 1.0 bar boost. :(
Apexi power FC
Greddy Profec B elec boost cont.
3" turbo back exhaust (catco hi-flo cat & dump pipe, X-force cannon muffler)
600x300x76 FMIC with full custom plumbing
HKS pod filter in FL guard - best cold air intake i've ever seen!
Sard adj fuel pressure regulator
Walbro 550hp 250 lph in-tank fuel pump
stock injectors - about 80% duty cycle i think...
Unfortunatley I didn't get the chance to dyno it beforehand so i'm interested to find out what the power difference is. I'm guestimating they make around 100 - 110 rwkw but if anyone's actually dynoed a stocker, i'd love to here what they really make!
Cheers
https://www.sau.com.au/forums/topic/69509-atw-power-for-a-stock-rb20det/
Why such low power figures?
Is your car 1989, or does it have a series 1 rb20 in it??
Those mods should see atleast 180rwkw, if not more...
Stock standard ive seen one dyno at 104rwkw to help you out!
Yeah the bloke at Unique Auto Sports says those mods should see 170 - 180 rwkw, but then he said that i am only running 14psi plus its a stock turbo...hmmm. I've got to back and see him for a few tuning tweaks and i need to double check the injectors so i'll see if there's any difference then...
104rwkw - cheers!
Ye... you could run 1 bar (0.7psi more) but wud of thought u wud of got more.
Maybe u have a series 1 turbo, these are a fair bit weaker and have different inlet manifolds too!
No stress... bigger turbo time :( Esp with those supportin mods!
Why would you have thought he would make more power?
As for different manifolds and differences in turbos, Series I and Seies II R32s :confused:
From what i would have gathered, 166rwkws is on the money:)
Meant engines dude! Not the actual car... lol
From what ive seen those mods WITHOUT a power FC can make up to 250rwhp... hes got that ontop..
Im yet to see a std turbo R32 GTST make 250rwhp, big thing with the Pfc is that the power curve/tractability of the engine should be improved...the turbo can only flow what it can flow, but the Pfc can help improve mixtures and response.
Another thing, i dont know how true this is as its just an observation, but the R32 ECUs appear to be far more flexible then the later R33s which insist on doing silly things with fuelling and ignition when you wind up the boost with a few breathing mods.
The R32 on the other hand does a pretty good job of adjusting to the new airflow requirements of the engine....
lol...That said, does the car drive any different with the tuned PFC now:)
Bigger turbo time = nothing makes me more moist!!!! :aroused:
in time an HKS GT RS will grace my exhaust manifold...
mines a 1992 build so its definitely a series 2 engine & turbo...very odd that the power figures are less than what others are gettin with similar / less mods
also i am running quite wide rear wheels & tyres - 9" wheels, 255 tyres - would that affect dyno figures?
No stress... bigger turbo time :P Esp with those supportin mods!
I had mine when it was bog stock standard on 2 different dyno dynamic dyno's.
D&T Performance - 113rwkw (hot day 98RON BP Ultimate)
RPM Performance - 115rwkw (cool day, 95RON BP Premium)
Check out some of the dyno run scans on the D&T Performance website.
It gives you an idea how the stocker rb compares to the ls1's, 200sx's etc.
I later had mine on the RPM Performance dyno, ran 1bar with a FMIC, 3" Turbo back exhaust, a little bit of extra ignition timing and fuel leaned out slightly via fuel reg modification. It made 164rwkw.
A turbo can only flow so much air before it begins dropping efficiency.
This is why RB20 turbo's tend to drop boost UNLESS you run a good ebc that can vary the duty cycle at higher rpm. (AVCR or Blitz SBC-ID)
With 1bar holding to the redline it should be up around 170rwkw, and maaaybe 175rwkw if its a cool day. It all depends on the tune, how rich it is running and how agressive the tune is (ignition timing)
this is strange my car with front mount. 12PSI and zaust has 141 KW at the wheels. i am sure u should get more then 166KW. maybe something worng with his dyno. The Power FC should atleast give u 20 - 30 KW on its own
i just wish ppl would stop comparing their dyno results to someone who has dyno'd their car on a different dyno in a different state. workshops can make a dyno read as high or low as they want it to. run it down the strip, at least that gives you a better indication of how quick your car is imo.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
