G'day,
Sorry to be a pain, but does anyone know how to set the clock on an Addzest ADX5455 CD player?
I've checked out the Clarion website (the associated company of Addzest) for a manual, but their instructions for similiar units don't work. :)
Any assistance would be greatly appreciated.
Thanks.
https://www.sau.com.au/forums/topic/6952-addzest-clock-setting/
Guest SPOOLIN
I have the ADX8455 but my manual is in Japanese, so ill do my best *dodgy* translation.
1] push adj button.
2] push up or down on the volume wheel( round thing) till "clock" is displayed.
3] push play/pause/ent button(middle of the round thing).
4] move left or right on the volume wheel.
5] move up and down on the volume wheel.
6] repeat steps 4 & 5
7] push play/ent button.
8] push adj button.
hope this helps
Lee
  • 7 months later...
Guest Mr Benz
Did you ever get the time set on your ADDZEST? Do you still have it? If so here's how you set it.
1. Turn the ignition to ACC position
2. Push the DISPLAY button until the time shows up
3. When you get to the time press and hold the the BAND and #4 buttons at the same time
4. Watch the display where it has the 4 arrows...you should see the yellow writing disappear and the "HOURS" start to blink on the time
5. Adjust the hours up or down by pushing the 4-way button either up or down
6. Push the 4-way button to the right or left and the minutes should start blinking; repeat the up or down like you did for the hours
7. When you have the time set, push the BAND button again and you're done!
If you have any questions please reply.
Wendell aka Mr Benz
You can have your webmaster remove me now, I just wanted to answer your question. (I stumbled upon it while searching GOOGLE for the same problem you were having)
  • 4 weeks later...
hey guys,
there is this guy selling an Addzest VAX787A screen and cassete deck.
not sure if there is an Fm expander cause he says there is fuzz but when he pulls out the deck, the anttanae wasnt connected.
so anyways, how much does an fm expander cost anyways?
what does the screen do?
it doesnt come witih a changer and there is another guy sellin an addzest changer.
Can i safely assume that any addzest changer will work with the deck as it has a changer control saying disc there and etc.
what is the screen for anwyays?
cant read japanese on the addzest sites anyways and there isnt one in english!
:D
thanks guys
sorry to steal yr thread tho...
  • 7 months later...
  • 3 weeks later...
Ahh.. Don't you just love those double DIN aftermarket japanese head units that come installed in alot of skylines along with all the other goodies... I have a Addzest MAX-4555z GPS/TV/CD/MD, touch screen motorized head unit, with CD stacker & Addzest NAX-010VD (GPS Car Navigation & DVD-VIDEO) system. It's very cool.
I still havent discovered all the features of the unit, so many configuration options. It has digital sound processing, graphic EQ, full screen graphics, etc. Unfortunately the DVD player is not multi/region 4, and the TV tuner is NTSC only but I still love it :(
If anyone knows a specialist installer or car audio workshop who can convert the DVD player to multi region PAL, and convert the TV tuner box to receive australian TV frequencies let me know.
G'day,
I've checked out the Clarion website (the associated company of Addzest) for a manual, but their instructions for similiar units don't work.   :D
Thanks.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
