  • Replies 57
yeh I have cam gears in mind, and I might go with the cam gears and the S-AFC. I do realise that the power fc is much better because you can adjust fuel as well as ignition, but i simply do not have the funds.
What sorta power increase would we be looking at?
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-102946
I will tell you saturday after I have dialed mine in. :)
I have just fitted them this week and will be putting it on the dyno Fri/Sat to set it up properly. I have boost up, turbo back exhaust, pods, and now the cam gears. Should be pretty similar to yours. Will let you know.
Mick.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-102966
Save for the power FC, it's really worth it! Midrange power is heaps now, and distances between corners seem so short. Why waste money hooking up and tuning an afc when the power fc is da bomb??? If you can afford a gtr, I'm sure you can afford a power fc. In the end you'll probably end up getting one anyway.
If you really want to spend the money now, suspension. Swaybars really help the R turn in better, and stops bodyroll. 1470kg isn't exactly light.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-102985
Originally posted by BoOsTeD_RB26
orrite sweet......make sure u lemme know
what kinda power u got now?
Will let you know as soon as I do.
The other day we had 204rwkw but that was with it leaning out like crazy at the top end and with 13 odd pound. I have just today replaced the AFM which were stuffed and it has picked up heaps.
Mick.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-103011
Silver-Arrows: what kind of performance gains did you get?....the suspension has already been done by the way. the mods i listed were only the mods associated with the power of the car.
how much would a power fc set me back....but just the FC....not hand controller...perhaps i will consider it but i dunno..have to see.
an additional odd $700 seems alot for just the fc.....what are the benefits of the fc?
either way...im definately going to get the cam gears
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-103027
The FC i brought was second hand from Nengun. It was about 1300, but an additional 300 for the hand controller.
I got it tuned, but they tuned it at only 0.5 bar boost. It made a lame 160kw on all 4 wheels. The tuner selected the option of boost controller kit to on, which I don't have. That's why boost was only 0.5 bar. I fixed this today and it's running at 1 bar boost. Don't know how much power, but trust me, your brakes are going to need upgrading.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-103054
yeh brakes will be a bit of a worry :(:P
also..was there much difference in performance from 1bar/stock ecu to 1bar/powerfc?
Oh yeah!!! :)
I love the way the car pulls away now. Before it didn't have much midrange punch. Now it just pulls away and leaves me grinning like an idiot. People give me funny looks after I've stopped and try to take in what just happened. :cheers:
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-103311
hahahaha...thats what I want to hear :(
has anyone here fitted an S-AFC to their gtr....if so what was the performance gain like?
surely an S-AFC and adjustable cam gears would give some wicked mid range?
Silver-Arrows: have you got any other mods like Cam gears?
EDIT: with the sort of power you'd be making with these sorts of mods...would the ceramic wheels in the turbos be a problem? (last long?)....keep in mind only running 1bar.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-103326
Little. BOV's, air filters, cat back exhaust, thincker FMIC, bigger radiator, oil cooler. Oh, I've put cable straps around the intercooler piping. They expand under load so this stops it from expanding, and spools up better. It helps. $2 for a stack of cable ties, can't complain about cost there.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-103336
Should not be a problem if you stay 1 bar or under.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-103367
Although I believe the powerFC is a very good ECU replacement (and I was amazed at the number of options of tuning it had when my friend fired his up for the first time the other nite) I wonder how much bang for bucks it has when running the ceramic standard turbos.
I was in exact position about 3 days ago choosing between powerFC and SAFC and I got the SAFC cos I thuoght it would do almost (obviously not AS good) a job but saved around $1200 or so from a second hand powerFC. With $1200 you can do quite a lot of other shit and I'm intending to spend it on cam gears + front pipes + dump pipes.
But its all up to you.... when it comes time to get bigger turbos I'll get a powerFC then. In terms of pure power the cam gears + SAFC are more bang for bucks... the powerFC allows you to do more later and adds efficiency throughout all tuning aspects giving more balance.. but at a price.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-103503
Ok finished dynoing the car last night. Took ten runs to get it right with lots of tinkering in the mean time. Got 240rwkw in the end but most impressive of all is the way that the car feels now. Smoother, far more low down throttle responce. It has over 200kw at 4200rpm. It is very toey down low. Far more responsive and much nicer to drive. It feels heaps smoother and easier to drive off boost (not that it was difficult b4 but it is way different now).
So BoOsTed go for it. It is a big difference. Well worth it. Just take your time and set them up correctly. Every car is different and needs slightly different settings.
Mick.
https://www.sau.com.au/forums/topic/6959-gtr-mods-what-next/#findComment-104354
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
