^^^^ I'm with not so stupid.
SAFC only does fuel maps (so to speak)
I belive the Chip allows for timing changes as well.
Speak to TOSHI from these forums.
Many people have used him with great results.
Very good pricing too.
PS: 16psi on rb25 turbo hey...
Starts taking bets on how long till it go kaBLAAAMOOO
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1287553
trevvy: please forgive me for hijacking but u just posted what i was goin to post...
can anyone give any insight on a unichip compared to a safc II? both can be had at the same price (roughly). safc can only do fuel whilst unichip can do fuel and timing.. are they worth it ... i want roughly a 15+ kw gain ..
edit: i heard toshi also does a remap/daughterboard for r34? anyone have any experiences? i'm interested as i want to get it tuned by the top secret guy coming to australia mid May
reason why i'm not goin powerfc is due to my car being a tiptronic
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1287555
apparently u can run more boost thru the rb25 turbo on the rb20 because it isnt flowing as much air to create the same boost, big thread on it i will find it tonite
thanx for the prompt replies
Trev
I still wouldn't push it past 1 bar.
1bar on the track would be pushing it though.
I know of a R32 RB25 turbo pushing 14psi that made 190rwkw. :cheers:
Chipped ecu, Blitz SBC-iD EBC, Pod, FMIC, 3" Exhaust.
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1288743
For a street car, go with the chip.
There is not much that cant be altered.
eg.
LEVEL 1: speed cut change/eliminate, rev limit change, boost cut change/eliminate.
LEVEL 2: fuel map adjustment, ignition map adjustment.
LEVEL 3: rpm scale adjustment, load scale adjustment (for higher boost levels).
LEVEL 4: injector size re-scaling, AFM re-sizing.
Its all do-able, if you can fit an eprom!
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1292194
Yes, the injector latency (sometimes called void blast off time) can be adjusted.
This is part of the issue with the 550cc RX7 injectors, the other is they may not be exactly 550cc/min. Hence, the injector setup parameter may need to be further tweeked for 'best fit'. It may take a few trys but do-able.
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1293448
Can the SAFC2 do the following:
1. speed cut change/eliminate
2. rev limit change
3. boost cut change/eliminate.
4. And is it possible to have both the chip and safc2 on board?
Suggestions follow;
1. No
2. No
3. No such thing as "boost cut", there is protection from excessive airflow. AFM voltage benders such as SAFC, DFA. EManage etc can be tuned to lower the AFM voltage signal to the ECU. Hence it doesn't know about the excessive airflow.
4. Yes.
Hope that was of some help:cheers:
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1305350
It feels like basically you guy's are saying the SAFC2 is useless, What kinda gains can be had with one does any one hare have some real experiance with them?
What gains/losses have been seen. Cause lets face it they are a much cheaper alternative to aftermarket EM.
( I know that aftermarket EM offers alot more control and tunability but 1500 to 2000 for supply fit and tune, Compared with 500ish you can see why there would be a market for it, ( If there are gains to be had.))
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1305448
I have an SAFC2 in my car (series 1 R33) i got my timing and the SAFC2 tuned and only 1 psi boost increase resulted in 36KW at the wheels increase. But to get the SAFC2 running properly without fuel cutting they had to install a FCD.
Take a look at my dyno graph. Note the dyno graph is just to show the increase its not what my car is actually making at the moment. Cheers
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1305999
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
