After any sujestions for connecting a Mini Disc player into my sound system. I have a normal CD Head unit connected to two amps one running splits the other a sub. Both outputs from the existing head unit run the amps. I would like a system within the cabin where I could switch between both the MD and CD player.
Thanks for any help.
I havent approached a car audio place yet.
https://www.sau.com.au/forums/topic/6964-md-connection-help/
What brand/model deck is it?
I know Pioneer sell an auxiliary kit that has rca inputs. it works via the p-bus system (same plug for pioneer stackers).
No idea on cost, but that's the best way that i know of.
The other option is to just buy a MD/CD combined head-unit. Or even better, forget the MD and get an MP3 unit. They are sooo gooood!!! :D
https://www.sau.com.au/forums/topic/6964-md-connection-help/#findComment-104605
It is a Kenwood head unit so I will see if they have the same device. The MD is MP3 compatable as well as Atrac, WMA and WAV natrually. As well as up to long Play 4. Records from any media including fibre optic for true digital as well as USB. So as you understand it is not going. If anything goes the headunit could except the fact I wouldnt have radio. The MD alternates between two cars, pushbike and air travel at work and the gym on rare occasions.
https://www.sau.com.au/forums/topic/6964-md-connection-help/#findComment-104609
This can be done. I'm planning to add a Creative Nomad Jukebox to my stereo soon. If you wanna keep it cheap and simple then you'll just have to plug the MD in whenever you want to use it.
Just connect the MD player to the amps via the RCAs. Use the headphone socket on the MD and plug a PC audio cable into it (the one that runs from the sound card to the speakers, ie headphone jack at 1 end and 2 RCAs a the other). Disconnect the RCAs from the head unit and plug them into the PC lead. You might need to get a few RCA jack to socket converter thingys (bout $2 each at electronic shops). That should be about it. In effect, the MD becomes the head unit. Just plug the RCAs back into the head unit when you want CD/radio.
I'm planning to set up a bracket in the centre console compartment to hold mine. The RCAs will come up through the bottom of the box and go to the amps and head unit. So all I'll have to do is just connect what I want, and its all tucked away neatly.
A few things to remember:
. If you have more than 1 RCA pre out one the head unit, you will lose fader control with the MD.
. If you want to connect the MD to both amps you'll need RCA spliters/double adaptors (again, about $2 from elec shops). Make sure the right channels are connected to other right channels only and vice versa.
. Does the sub amp have a built in crossover??? If not, dont connect the MD to the sub amp.
. When you first play a MD, make sure the volume is right down low. The gain settings on the amp might not agree with the signal coming from the MD... but this should not be a problem.
. This whole set up should only cost about $20-30 and take maybe 2 hours to install. I'm not sure of what quality of sound you'll get tho.
https://www.sau.com.au/forums/topic/6964-md-connection-help/#findComment-104845
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
