Hey guys got 3x17x10" wide rims for sale.
When i bought the car it only had 3 on so sorry bout that but.
10" wide are very expensive and hard to come by.
Perfect for drag or track racing etc. wouldnt be hard to find another if you wanted a set.
the current 2 rear 255's are down to the belts, and the front 235 has 75% tread left
$600 neg
They fit on my 300zx. R33 GTS-T rims fit my zed so i assume they will fit all skylines with the same pattern as R33gtst's..
pick up only.
0405400170 or e2ek1el21@hotmail for MSN or email.
Peace
Matt.
https://www.sau.com.au/forums/topic/69683-fs-17x10wide-mags/
sorry dude i dont have a skyline, your welcome to come try them on for yourself.
Ask doughboy, he may be able to send pics for you
im QLD. gold coast
offset for 300zx is 114.3 and they fit sweet as front and back on the zed.
im QLD. gold coast
I think you mean PCD is 114.3
offsett is distance from the wheel hub to the centre of the rim sorta of a measure of how far the rims wll fit inside the guards
well dont think I can take up that offer anyway since Im in WA ahahha
give us a pm if you're willing to send maybe I'll consider it and a pic on the zed would also help since from memory I think Z32 and R33 GTS-t have very similar offsett on the rears. Just to see how it fits inside the guards
yea my bad, PCD 114.3
probably not going to be worth posting as wheels and tyres are heavy, 30kg in post will be killer! especially to WA
they sat in my gaurds a few cm's but my zeds lowered an inch which makes it worse.
ive had an offer of $350 but im really after $500 guys.
you wont get 10" rims this cheap anywhere. theres $150 worth of tyre on the front rim alone!
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
