hi, im gonna get my car conplied as a 2 seater, just wondering if in the future I wanted to switch to 4 seater is it possible?, ie thru an engineer or something?
or does it mean it will be a 2 seater forever
and does anyone have any other info on complying a 2 seater that might be useful that would be great.
cheers
https://www.sau.com.au/forums/topic/69791-complying-as-a-2-seater/
cheers
Yep you can engineer it as a 2 seater but if you do want to change it back to a 4 seater, another engineer's certificate is needed. Wouldn't it be easier to engineer it as a 4 seater? It's gonna cost more in the long run if you start off with a 2..
quick question......my car is already registered....how would i go about changing it to be a 2 seater or a 4 or 5 seater with conditions ( or was it a 2 seater with conditions)? All roll cage related.
    • Oh please, when has anybody really been "done" when they say that? 😂
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
