Steve,
My thoughts exactly, what made me think there was a restriction some where in the exhaust is the way the curve flattens out in the top end on the high boost setting.
The power curve can be influenced by the ramp rate a little, but it still looks a little slow getting on to decent boost.
As discopotato once said with this dyno graph... Pumping losses.
  • Replies 159
how can yours fry the tyres, when mine makes the same power and everything, 200rpm later is the only difference and i have not one problem with traction. ??
Judging by your nick, youve got a R31. Maybe they have a softer independant rear end than the 33 or much stickier tyres The 33 is slippery, even i get sideways movement in second once i come on boost with a 2530. Count yourself lucky you dont have these issues. First gear is useless. Ive converted back to stock suspension to get some more grip.
HICAS, too high rear spring rate, poor suspension geometry, too stiff/poorly valved rear shocks, worn sub frame bushes, too high tyre pressure......etc
:D
first gear is fine, unless im saveage on a launch. If i am smooth then its totally fine unless im nasty with 1st/2nd gear change then its skating
My rear end is more prone too loose traction than an R33 due to the primative design of the R31 IRS
Ask any coupe owner than tries to get grip, its a mission due too squat and the sheer camber that ends up on the rear causes around 2/3 of the tyre to actually touch the road.
And im only running 245's on the rear, just cheap sumitomo's that in my opinion are very average. Thats on 18's too...
I agree with you SK, some of these guys cars must be shockingly setup as i wouldnt even say my setup is anywhere near what i could be.
still, im at a loss :headspin:
Maybe you dont have the power you think you have then. What Sumitomos you running, im running the HRZ 11, 255/40/17.
So many variables. I spent alot of time and money setting up my skyline so it didnt do crazy things.
R31 - non IRS too isnt it? IRS has its own challenges. Just being non IRS and no HICAS would give a car massive advantages until you sorted the issues in a car that is equipped with IRS and HICAS.
Making the power is only half the job IMHO.
Sorry forgot to add, just because two cars make the same peak power, run the same boost and come onto boost around the same rpm, doesnt mean they have the same power over the rev range.
Car A at 1 bar may be making 250rwkw @ 4000rpm, car B may only be making 180rwkw at the same rpm and boost. Both may make 300rwkw peak power. The shape of the curve makes a big difference too.
HR31 has IRS and HICAS
HICAS i still retain, and all of it is very primative.
And i have 270rwkw, there is no doubt about it. Rolls off Race Pace Dyno as such :rofl:
See what it makes next weekend @ AutoSalon... :)
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
