Why do you want one? They are really only useful in rally cars and motorkhana cars; absolutely no use - or benefit- in a road, or even a race, car.
AFAIK, they aren't manufactured for a specific car - they are pretty generic.
If it is your only handbrake, if not illegal, it's at best pretty dangerous. The fluid can cool and contract, releasing pressure on the brake. IIRC, a guy "lost" his car, and found it several hundred metres down the road, across the other side of 4 lanes of traffic! It didn't hit anything - how lucky can you be?
I was thinking that drift cars use these.And seen as though i may see a drift day or two,it maybee worth my while getting one.
Are there any difficulties experienced drifting with cable handbrakes?Other than i suppose the stretch they would have after a few thrashes.
well they only really involve putting a master cylinder in the cabin without a resoviour, so that it connects in between the master cylinder and the rear brakes...the one i had in my past car involved re-routing a section of the rear brake line into the cabin through a master cylinder that would normally be used on a trailer, that had an in and and out instead of an out and a resovoiur, then just modified a handbrake i got from the wreckers to activate it...you can buy hydraulic handbrake setups from places like race-and-rally i think...
the master cylinders look much like this one...
could probably set one up like they have in the rally cars so that it's a seperate handle next to the steering wheel or something :P hehe
So you recon a second handbrake could be intergrated into the car totally dissmissing the cable handbrake when i dont need it.
Are the drifters of the forum experiencing any problems with their cable handbrake.B4,during and after drifting?
I.e.Excesive stretch,not enuf bite as what you need.
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
