Ok mods I know the forum has a wanted section and that I could infact go and look at all the for sale cars but I have done that several times.
A problem with the forsale section is that its Australia wide making it damn hard to find a perth buyer or seller.
Regardless please move this if its in the wrong section.
Im after a white or black R32 GTS-T two door MANUAL Skyline in perth, I havent had my R33 slush box "auto" for long and only a few of you have seen it but its sold 2 a mate thats picking it up in 2 weeks!
I now have upto $14'000 to spend but if I can get one for under that I will be a very happy guy.
Mega Motors have a few for sale around the $14'000 mark so If you have one with Rims or an exaust etc etc please ring me ASAP or email me ASAP
PH: 0431928164
Email: [email protected]
https://www.sau.com.au/forums/topic/69878-wanted-r32-gts-t-asap-within-2-weeks/
mega motors is great, i got my car from there... i forget his name, but the guy i dealt with was AWESOME... helped me out 110% !
(u can bargain him down wicked too LOL... i knocked almost 2 grand off of the price he was asking LOL)
even afterwards, i had no tool to get my wheel nuts off, i called him up about it (prob 2-3 months after) and he said yep no worries, jus go buy one, then come down and i will refund ure money ... and he did.
Awesome, thanks Dan, Ive spotted a damn nice R32 at Mega Motors and think I might try and get it this week.
1989 R32 GTST Black, Manual just under $14'000
If your reading this please speak up if you have an R32 for sale as you can see im buying a car soon!!!
* will look at R33's if anyone has one at this price?? " probably autos" but would rather a manual.
Man Ive gotta stop looking at the prestige motorsport we page, I keep thinking how much id save importing... MMMmm.. From advise Ive recieved on this and many other pages I think local purchasing is much better.
yeah dude, keep it local if u want ure car quickly :P
But yeah.... *looks around for car papers
okay, yep... the guys name is Steve Turner
he seems to know a bit about skylines, compared to normal knob dealers :P
he is a top bloke
mobile no. 0418 926 663
tel: 9430 7920
but yeah, goodluck mate!
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
