mark had fun drifting someone else car though:
Pete, what a top day of drifitng. kero was right the level has certainly been raised.
Also, thanks for the ride in the 31. what a beast... the car was ok too.
  • Replies 96
yeah thanks to andrew for lending me his silhouette
good bloke
always fun breaking someone elses car!!
fixed it for you mate. yeah he was a sport. he wasn't even that bothered when you broke his suspension on the curbs :(
Pete, that patrol is a machine mate. shame the other dude was too soft to get a decent smoke show going.
Top day.
The patrols circle work was pretty good but I liked it better when you were manouvering over the dirtbike jumps, even if it did bottom out hehe (background of above pic).
pete, you can read me like a book...it's scary. i would have offered mark a straight swap for the GTR but I know there is no way he'd swap such a sweet 31 for a 32.
thanks 4 the sweet pic of my car mmmgtir. top day. no worries about the suspention, its fixed already. a car is meant to be driven!
haha, good news :P
Mate I've got a couple of decent pics. if you pm me your email address I'll send them to you.
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
