i have rather locked rear end....
I should say if I stand on the brakes it put enough resistance on the diff to get it to move.
Id say its suspension tho... if the wheel is off the ground, the suspension doesnt have the travel.
its going to become handy if i wanna change the oil i guess haha..
but i dont think its the suspension the main cause.
i have cage, body's been re-enforced with many more welds, one of them do-luck bars,
its like a sea saw when you park it in the right spot..
i have full race roll cage in mine (no rear seats, sun visors etc etc). Chassis don't flex that much. (well not on our cars anyway!)
I know what Daveo is talking about my ceffie gets beached, JIC suspension and a 2way, I jack the car up from behind the front wheel and 3 wheels come off the ground!
I love my suspension on smooth roads but... our roads generally suck so its annoying at times!
It's actually a case of your chassis being VERY stiff and NOT deflecting. This is a *good* thing (I'll get back to this later).
The fact that your chassis is welded and has a bolt in roll cage means that the torsional rigidity of your car is significantly improved. Thus, it takes much more twisting motion to flex the body. An illustration of this is, when you jack a car up at one corner, the windows and doors tend not to fit quite right. However, when, if you've got your car jacked up at one corner, the doors *may* open and close properly. ie. stiff chassis = good for maintaining suspension geometry and thus handling.
The *good* thing that the wheel is in the air now... It is good because it illustrates that your chassis has been reinforced well. However, it also illustrates that your shockers, at full extension, are significantly shorter than the factory stuff (same as my car). What this means is that, the shock length is shorter and thus the 'droop' that the wheel had drop to is shorter than the original factory suspension. An example of this is when you see a 4WD with very long travel shocks / springs climbing rocks that can articulate the left front wheel entirely within a guard and the right rear wheel at full extension that leaves a wheel to guard clearance of 50-100cms (see below pic)
Escursione%20sui%20Nebrodi%20Domenica%2021%20Sett%202003%20in%20compagnia%20dell
So all it means is that you'll lift wheels when getting into / out of driveways etc, you'll notice that Porsche GT3 RS's do it too...
So, if you've bothered to read this far, this is a good thing.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
