I've heard that HKS pod filters stop only "small birds and rocks".
Apexi is "supposed" to be the best. I'm currently using a noname cotton job, when I get the money together I'll get myself the apexi. I've also heard K&N is good (i.e. some of their pods register no change on a chassic dyno when run without filter to running the K&N filter, off course I don't know how well they filter).
https://www.sau.com.au/forums/topic/70664-pod-filters/#findComment-1304033
why not an aus brand??
because a pod filter is the biggest piece of 'wank' in the engine bay, one of the only places to show off that you actually have a japanese part. they all work in roughly the same way, just depends on what brand you like and/or use.
i have a super metal flow and dont have a problem with it, just take it off and rinse it out with a hose once a fortnight. over the years ive had a cheap $30 cheapie, a K&N dual cone, super power flow, apexi super intake, the cheap one couldnt be washed, the K&N covered the afm with oil from new, didnt have it on there long enough to get dirty, the super power flow made a large difference (for a filter), was quite happy with this filter, but the foam started to fall apart. the apexi got dirty like the others but didnt come up as clean as the power flow when washed, it ended up getting clogged, so i spent a few $ and got the metal flow....made a really big diffference over the apexi, it sounded different, not a harsh sucking noise, smoother power delivery and a crisper engine note.
but it all comes down to what you like in the end. it makes sense to carry on a theme/brand.
cheers
Linton
https://www.sau.com.au/forums/topic/70664-pod-filters/#findComment-1305730
just a question, would the oil type k&n pod filters cause any insurance claim issues ?
i know its legal to have 1 intake system. but im not too sure about the oil type filters.
ohh, and the answer to this thread. apexi is the best pod to get, followed by k&n.
some of the other well known brands have bad filtration.
https://www.sau.com.au/forums/topic/70664-pod-filters/#findComment-1305745
The insurance question is best asked of your insurance company. You should probably only take financial advice from people who are authorised to do so and with the proper documentation :)
I can however give you general advice, which doesn't relate to your situation and does not take into account your insurance policy or situation.
Most insurance companies may say the car needs to be legal, if the part in question isn't legal, then they may refuse to pay... but this is a moot point as it dirties your AFM anyway so why would you want one?
Either way make sure it has a shield :cheers:
https://www.sau.com.au/forums/topic/70664-pod-filters/#findComment-1305879
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
