Hey guys, I was talkin to this fella today who was saying theres a skyline about that has a shitload a grunt and running NOS. I didnt get his name but he works at Robert Fergusson's, does anyone know who it is or the car?
Id like to quiz him on what NOS kit hes running, might be my next upgrade :bananaman
https://www.sau.com.au/forums/topic/70759-anyone-know-this-guy-or-car/
Yeah i know the car it has a t04 has deen dynod at 450hp i think. Its a black R31.  It was in the trading post for ages.
I recon it is Max Grifith's by the sound of it, its not running NOS though and its putting out 500bhp.
The car is a R31 coupe with RB25 dont know what times in does. His name is Fergus i think.
I have a R33GTS-T
12.4 @ 117mph was on street tyres i was limited to only 14psi will be a lot faster next time. With the new computer and more boost hopefully get into the 11s
I have a R33GTS-T
Sounds pretty impressive, but so does whiter33gts-t's new mods. When you running the car next champ?
I have a TD06-20G, high mount manifold and external wastegate. Dont know what i will do with it as yet. Might see how much power i can get then sell as a complete engine.
Have you got any internal mods on this engine?
R you gonna go RB25/30 for your new engine?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
