ahh the joys of being new to a forum! anywayz i also got a auto r32 gtst, can exactly comment on how they drive...cos i havent driven it yet!! (still sitting in the docks!)but that button is essentially the same as silvia s13's. in power mode the auto will hold its revs more, hence try and keep the engine on boost more = more power/acceraleration. hold mode has many mixed reasonings, buts its use is basically to stop your car wheelspinning when you take off from the lights. in hold mode the auto will start from second gear, not first, hence reduce wheelspin.
https://www.sau.com.au/forums/topic/70844-r32-gtst-auto/#findComment-1313064
thanx j_r32, its my 1st rwd n turbo car so im stoked! it corners good n if u rev it right u can come out of corners hard n fast without spinnin much coz the HICAS helps correct itself.
i suggest getting it lowerd tho n fatter tyres!
https://www.sau.com.au/forums/topic/70844-r32-gtst-auto/#findComment-1313221
hmm to be honest this is my first turbo car, had two na silvias previously so i am not very keen on getting it sideways! silvia was a different story hehe.anywayz take it ez on the streets, skylines need to be driven with respect. :P
https://www.sau.com.au/forums/topic/70844-r32-gtst-auto/#findComment-1314589
Snow/Hold mode. Makes you take off in 2nd, limits revs to a max of 4000rpm Before the change to the next gear.
Power - Allows the engine to rev out in all gears cleanly to redline if asked to before next gear change. For when you are driving enthusiasticly.
Also if you stomp it and its not in poswer mode, it may decide to go into powr mode anyway.
You can also quite easily manulay shift down with this auto box, and hold a gear through coners/roundabouts etc for maintaining better power/revs and not have it changeing up mid corner! (be warey)
https://www.sau.com.au/forums/topic/70844-r32-gtst-auto/#findComment-1314879
that would depend on the condition of your auto box, it should change close to redline about 7000rpm, since redline is 7500 if i aint wrong??
just one query is downshifting a auto (ie going from d to 2 to deccerlerate) bad for the auto box?
https://www.sau.com.au/forums/topic/70844-r32-gtst-auto/#findComment-1324959
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
