Hi everyone,
I'm waiting to pickup my R33 GTS-T from the previous owner and there was one question he couldn't answer about it.
The unit has an inbuilt LCD screen which controlls the sat nav, cd stacker, am/fm radio, audio equaliser and TV Tuner and, yes, get this, tape deck!!
I didnt check for the brand when I test drove the car, but later on when I spoke to him he said it was a Nissan branded unit.
Has anyone else seen one of these? I'd like to get as much information about it as possible, a manual would be even better!!
Any help appreciated.
Thanks,
Mike
https://www.sau.com.au/forums/topic/70879-sat-navtv-tunercd-stacker/
yep they are lots of funs to remove and the stacker is a sony A30 unit. they are indeed factory fit on these cars and removing one involves a LOT of rewiring as EVERYTHING is tied to a module behind the rear seat. can't remeber the make of the actual unit but clarion ( denso) rings a bell for some reason.
as usual the nav/tv wont work here. the stacker will be on its last legs as well.
have fun..
have fun..
Hi Chris,
The unit has Nissan CW726 written on it. It has a 7" (approx) screen that shows either current radio station, cd stacker info, tv or input from the front mounted a/v inputs. The stacker itself has Nissan written on it too, and its a six stacker.
Any ideas on where I might get information on it, google returns one link (in japanese) and thats all.
I dont think its a Clarion unit as I believe those units allow the screen to retract into the dash, this screen stays out all the time although the angle is adjustable.
Mike
its a clarion unit. ( the aftermarket clarion is motorised these arent.) nissan have used clarion in most of their cars for years. the only exception seems to be a xenavi item I worked on a while back.
Hi Chris,
Ok, thanks for that. So I guess I could try Clarion for some info. I'd like to get hold of a schematic diagram or service manual, at least that way I can see if it can be modified for PAL.
Mike
Hi Chris,
Mike
Check this thread here for a link to a company that does PAL conversions:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=67425
is it possible to get a dvd player to hook up to the tv that accepts pal dvds but converts to ntsc for the jap tv?
It may be possible, most of the current home DVD players can be set to output either PAL or NTSC irrespective of the DVD type, so you'd need to make sure the car versions do the same.
For me it wasnt about DVD tho, i was thinking it would be cool to be able to listen to the V8 Supercar races if I happened to be on the road at the time of the telecast.
mike
Yep, there are more than a few in-car DVD players that do just that, they have an NTSC video output on them so that they can be plugged into OEM screens that have a video aux-in connector.
Can you suggest any reasonably priced (mp3 + tuner) models ant?
best I've come up with so far (price/value/quality wise) is http://www.jvc-australia.com/products/_pro...ils.asp?ID=1397
ok that changes things:
try this:
http://www.audioexpress.com.au/shop/item_s...?code_no=VS9910
price ( I need to update mine) is $1900
I already have a ntsc tv that came with nav system. Want a single din unit that accepts pal outputs ntsc + mp3 + tuner. Similar to this http://www.jvc-australia.com/products/_pro...ils.asp?ID=1397
If you aren't too worried about the brand, found the following after a quick google search:
http://www.strathfield.com/Products.asp?CatID=186
There are plenty of similar cheap no-brand units out there.
Though that JVC unit is pretty good value for money I reckon, cheaper than some high end CD units I've seen!
  • 3 weeks later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
