gday chaps , got my first taste of clutch slipping the other day and my second dose tonight to confirm that its on the way out :D
had a good run though (2 years since i bought the car with it) with highish power so i cant really complain.
this is my first manual car so i dunno how it works, i wont be driving it on high boost till i get it replaced but how long should that be now that i've got some slippage
anyone reccomend a decent clutch for 33gtst with around 225rwkw?
cheerypoppins
Jim
https://www.sau.com.au/forums/topic/71010-clutch-dying-nooooooooo/
Extreem 9puk Ceramic Cushioned with a 1tonne pressure plate.
The 800kg pressure plate will also easily hold 223rwkw and be a little lighter on the leg.
It really is a nice clutch. Very nice hard grab yet it can still be rode slightly (for a second) before it grabs and gives a couple of slight thumps some times chirping the wheels. Very very streetable.
These clutches are getting around in quite a few 300rwkw RB's & 2JZ's.
Cost me $600.
dude i'm pretty impressed that you managed to keep that clutch going for 2 yrs with 225rwkw being your first manual.....it couldn't have been a stock clutch could it?
I've got an excedy 5-puk brass button clutch - bit of a bitch to drive thru heavy traffic, but its very nice for drifting, bites quite hard.
I just installed an Exceedy full face - will find out what model and let you know if interested. It is rated the heighest for the exceedy full face, sprung hub. (it feels very nice - not hard to drive!).
cost for me was $550 (for a full clutch kit)
Same here, with the 850kg pressure plate.
It's actually lighter than the stock clutch I had in my GTSt, and it bites really well. Cost 800 installed ($550 for clutch), and that also included replacing the spigot bush.
On the dyno I got 200rwkw, but i have a feeling it is closer to 190..
For street use this clutch it great...
I was going to get the extreem 9 puck ceramic cushioned clutch initially, but i was told to steer clear of it by the person installing it.
Hmm $550 is a nice price.
I went on Cubes advice and ordered the DCBHD for the sr20 with 860kg pressure plate yesterday. That's 9 puk ceramic. The engine is putting out 180-200rwkw (depending which dyno you wanna go by) and will hopefully be closer to the 230rwkw with some EBC action.
Hope it's good - a lot of people seem to use this on SAU (there's a couple of other threads about this in the last month or so).
Zahos - this is the first I've anything remotely bad about them, did that person say anything?
If anyone reads this and wants to know how I went PM me in a few weeks :P
Firstly I was told my driving habbits would chew through the flywheel. I drive in traffic and up steep hills to and from work and tend to sometimes slip it a little, and that the pressure plates are made from inferior materials and can be prone to premature failure.
My driving habbits are what led him to tell me to steer clear.
The premature failure on the pressure plate he has seen in very few cases. On this point he was trying to discourage me from it, didn't tell me I shouldn't get it.
Unless you are really unlucky, you should be fine.
In terms of driving habbits, need to make sure that clutch suits your application. If it does, then I wouldn't worry about anything if I were you.
I would be interested too.... :rofl:
Cost me $600.
sounds good cubes where did you get it? pm me if you like
and did you get the tonne or 800?
nah it wasnt, "apparently" and i say that cause thats what the previous owner claimed was that it was.. "apparently" a 33 GTR clutch modified for the gtst, but as i said thats probably not true cause the previous owner was a lying sack of shit... hi turbogtst :wavey:
has always been lovely to drive tho whatever it was
Mine is heavier than the stock GTR clutch and is rated to handle over 300rwkw. I'll check tonight to see what model and rating :rofl:
so if i get one of these but no upgraded flywheel will there be big probs?
All depends on your driving habbits.
It doesn't mean you will need to upgrade it, but just an issue of its longevity if you tend to ride the clutch a little sometimes. I wouldn't worry...
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
