Checking the battery is the obvious one.
When you push start it, it generally does take a while for the RPM to go back to normal so thats not unusual. It you had problems with the coil packs it wouldnt prevent it from starting it would just cause it to misfire.
Other things to look at are:
-Starter motor
-Alternator
Just look at all the things that could prevent it from starting but not affect the car once it starts running. But I would be lead to believe that it could just be the battery.
Cheers,
Have you got an alarm with an immobiliser fitted? Depending on how the immobiliser is wired can affect if / how the car will start.
Then again, a bit more info on how it won't start eg starter doesn't work, engine spins but won't fire, etc would be a really useful guide for a well-considered diagnosis of the problem.
  • 1 month later...
hey mine wont start either? it was running perfectly fine...the battery seems to be connected properly and there seems to be power in the car because the head unit is working the tt is functioning.
But when i turn the key it makes some funny noise like a high pitch sound as if it was coming from the alarm/immobiliser. does anyone know what this could be?
i tried it again and it started! i fiddled around with the connections a bit and noticed there was heaps of acid build up on the terminal. but yeah i did forget that the mechanic said to replace the battery as there was a crack :O so i'll be getting my new battery tomorrow!!
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
