Hicks , if your new clutch is one of those nine buttoned purple ones, I think you'll find its actually brass, not ceramic .
Don't really matter cos the lunchmaster , err * Launchmaster * aka Rhino aka Ryan has got one in his R and hasn't killed it yet with redline 4wd clutch dumps so you should be sweet.
BTW , I installed mine, went straight to the malaga test track and launched off the limiter on one of my previous R's so bedding em in is not really an issue.
cheers
I wasn't trying to revive an already dead or potentially touchy subject, but these clutches are designed to handle high horsepower, what if they shit themselves within a month can you expect a free rebuild or not?
See'ya :burnout:
See'ya :burnout:
If they shit themselves within a month its probably your fault and you should think about an even tougher clutch or one from another company.
I wouldn't give a warranty on anything like that. I mean would you give a warranty to a guy who says " I am going to do my best to kill this clutch anyway I can, so can you give me a warranty mate?". If the clutch guy gives you a warranty he's lost his marbles. He won't know that I am going to do a burnout whilst towing a house on a trailer will he?
If you want to go faster than factory you will always break things For the enthusiast you will soon learn it is almost 99.99% of the time your fault for driving the car like it was intended. It's like those people who get race engines built and expect them to last without a rebuild for more than 2 years.
Rev210,
I was thinking more that they claim that it can hold 500hp, and yet with your 300hp car the clutch still gets fried. I think the claims by some of the clutch manufacturers are not really accurate, as I'm sure my twin-plate would not last long against 600hp.
Even Macka's clutch is shitting itself, and he only has 300rwhp. Should we expect a clutch rebuild every 9 months as par for the course?
See'ya:burnout:
Rev210,
See'ya:burnout:
It depends how you drive, how often and how you like the clutch to feel. If you like to drive your car hard then expect to kill the clutch some times and your gearbox and your diff and your fan belts and your brakes and uni joints and center bearings and just about anything else you rely on.
Group A cars have the toughest of this, that and the other and they blow stuff up and wear it out at alarming rates. Why should you think any differently? if you do then you just get more upset when things break than you need to.:D
Rev210,
I don't mind breaking things, I was fully expecting my factory clutch to shit itself, and it did. I do however get annoyed when you purchase something and it doesn't live up to its promise. I do hope that I won't have to change the gearbox for a while, as that would be very expensive.
See'ya:burnout:
As Ken said I got one of Ross's purple jobbies in my R and have had no dramas in about 2,000k's of driving, and that has included an MC day, Drags and a whole heap of spirited driving. I bedded it in for about 500k's and since then I think it is getting grippier!!!
And yes I believe I have done about 20 or so 6,000-7,500 launches with it. That has to be the equivalent of at least 40 GTS25t launches, simply because of the extra load a GTR puts through the clutch.
Trust Ross's work and the product he uses, the list of Sau people with his work in their cars is growing andit aint cause he does dodgy work.
Rhino,
I certainly wans't suggesting or implying that the work at any of the clutch places here was in any way not extremely good. In fact I was more having a go at the claims from the Jap manufacturers, whose claims of supporting 600hp is wildly over-optimistic.
I'm glad your clutch is still going strong, as is my twin-plate. I was just curious if these products which are designed for racing/drags have any warranty associated with them.
See'ya:burnout:
Did it cost you about 800 bucks??
That is about right. The friction disc is $330, fitting $250, pressure plate around $220. or something. I only bought the friction disc.
Its definately a ceramic composite friction material. See below pic.
http://forums.skylinesaustralia.com/attach...=&postid=100035
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
