who was the guy in the DR30 drifting at Calder on channel 10 today??
For those who didn't see it he got knocked out in the first round but it was great to see a DR30 competing.
I think channel 10 should have done more of a segment on it but I might just be a little bias.
There was only 1 non nissan which was a v8 holden ute.
https://www.sau.com.au/forums/topic/71372-dr30-drifter-on-channel-ten/
It was Tom Monkhouse. His car is fuuuuuucking low, I swear it sits about 4 inches lower than mine.
The judging was shithouse going by a lot of what I saw today, he was pre-apexing better than the S13 and seemed to be getting the last corner better too.
His brother Jack runs in the ARC in a Galant, he usually shows up at SA drift days, used to bring his 180B rally car and then brought a VR4 converted to run rwd for drifting for one or two days at Mallala
It quite possibly could have been?? haven't heard a word about it how ever. Was it white absolutely dumped with 1800-nothing-suss stickers on it? I think there may have been a rally on over that weekend though because I heard this weekend he finished 1st over all in his newly aquired evo 8, not sure if that was this week or the week before. Spewin if it is.
Yes.... mine is rather high lol
But I havent had a cop look twice at it and I'm sure its the ride height
Tom's car has been slammed for almost as long as he has owned it 2 years now, I know because he got his the same week mine got complied. He has had one defect for bald tyres which he got of at the cop shop no worries.
Cops looked at my car a lot the day I drove it round with the gearbox and rails 50mm off the ground but that was just stupid and I didnt have the c-spanners to adjust my coil overs. I reckon my car got complied a lot lower than your car :wassup:
yeah think he got done for no horn to within that defect....Whats he doing with the computers???
I remember how low your car was Josh looked tough but!!
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
