Hi guys im new to this forum n i find this forum really interesting n great ! i should have came here ages ago....sigh wasted my time... anyway besides that i would like to ask about some drift questions
Im now comparing whether to purchase a 32GTS-T or a A31(cefiro) both with RB20DET....im wondering if they have differences during drifting manouvers or etc.
Cefiro here in my country is really cheap n the skyline is about more than half more expensive....
But the as for the spare parts from the chopshops i guess 32GTS-T is dominating
As for looks i would say the GTS-T has some sexy parts ... no offence to the cefiro owners ^_^ anyway thanks for reading n the replies!
  • 4 weeks later...
cefi;s are basically taxi on silvia floorpan...they can look very good with the right mods and body kits but in stock form the skyline would be better.....the body of the skyline is also more rigid......both need suspension upgrades regardless.....however u will find with most cefi;s or laurels if your interested that they are autos...not an expensive conversion to say the least but depends how much your willing to spend.....
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
