For Sale S13 parts:
2lt turbo gearbox with presure plate and clutch
2lt non turbo auto gearbox with torqque convertor, T-bar and tail shaft
2lt non turbo engine 1993 72000k's
2lt rear wing, black
2lt front bar, black
Drift style alloy wheels with tyres 15-16inch
all in excellent condition all in Queensland
email me at [email protected]
https://www.sau.com.au/forums/topic/715-fs-gearboxmotorfront-barwheels/
to cut a long story short I no longer have jpeg on my computer, so I can't up load them but I sent them to myself from my dads computer, so I can email them to people, if you don't mind whats you email so I can send them to you so you can put them up.
