bank sez its goto go!
1989 r32 gts-4 factory 5 speed rb20 4wd turbo 4 door
106,000km - Full service history from japan
brand new trust Front mount intercooler (500kms old)
gtr front bar
brand new hks hyper max coilovers (500km old)
brand new hks style dump and 3 inch exhaust system
hks 2535 turbo (been installed 500km)
apexi power fc ecu
tomei 256 cams
trust cam gears
profec b spec 2 ebc
gtr injectors
brand new extreme 9 puck clutch with gtr pull type clutch conversion (500km old)
17 inch work mesiter alloys
300 hp @ wheels
12.4 @ 109mph
6 months rego
car is in WA
its awesome to drive, handles great, and has the driveline to handle serious horsepower
$21,500
http://www.driveline.net.au/gallery/2005//...21/IMG_6783.jpg
https://www.sau.com.au/forums/topic/71635-r32-gts4-124-second-14-mile-21500/
posted in your other thread but.. anyway
interior and underbonnet pics?
price has gone UP?
yes price did increase as the following parts were added
work meister alloys
trust cam gear
tomei cams
apexi powerfc
new tyres
profec b spec 2 boost controller
price has gone UP?
hey mate
organising pics could be a drama as my camera is kaput
your welcome to come inspect the car if your keen
my number is 0410681212
sms me to organise
regarding interior and engine bay
interior is factory standard minuse profec b and power fc hand controller
engine bay is clean and tidy, all tastefully modified
i have all painted rocker covers and polished plenum for it, but i didnt install them, ill throw these in withthe car!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
