a club car? as in Improved Production? the thing would never turn in on the Yokohama A032R's! Those kind of rates are for racing slicks only!
It depends what your talking about. For road cars, this method will work adequately and keep a more comfortable ride, but for track work its totally the wrong way to go about it. Springs should be used as the primary tool for getting the balance right. Swaybars should only be used for fine tuning or adjusting the balance. Big swaybars can create big problems for track cars. If its for the road, I don't really know why you'd want (let alone need) to increase the spring rates - my HR30 is very firm as it is with standard suspension (even still has the standard 'adjustable' shocks! set on hard) and handles surprisingly well at standard height.
most club level race cars are built, setup and raced without ever being corner weighted. Corner weighting is about setting cross weights, which can make the last little 1% in becoming a genuine outright contender on the race track after everything else is sorted. It's not used for selecting spring rates. For a road car its a total waste of time.
As is adjustable suspension. It's useful for a race car, IF you know what effects a change in roll centre height, or bump/rebound adjustments will make, but for the road its a total wank. On a well setup race car, a 5mm change in front ride height can make a significant enough difference to the rollcentre and axis that it can totally change the on-limit balance of the car. A street car will be far less sensitive to the same change due to a range of reasons such as the much more conservative geometry and significantly lower mechanical grip.
Besides, 90% of street cars have the ride height dictated by aesthetics rather than function, and most just see camber as a way of getting bigger rims under the gaurds!
Harry,
I'm not going to get into debate over this, but let me say this, in a lot of respects your wrong, not all, but a lot.
The guy that is setting up the 200B club car was racing sport sedans before you were born. We were both competitors at a race track that you probably have never heard of, "Warwick Farm" and he was a very successful competitor, beating many bigger budget teams than his.
You obviously have your ideas and I have mine, but going on your age, you are obviously drawing on such a massive wealth of experience.
Setting up Nissan/Datsuns my way has paid off for me in the past and I will continue to do the same. At about when you were 1, I was throwing a 180B SSS around what is now the south circuit of Oran Park in a fairly quick 49.6 seconds. A fairly mean feat for an under 2L series production car and something no one else could do in the club at the time.
The car was set up by Don Selby in their workshop in Planthurst Rd Carlton and he has no relativity to the now Selby name, other than the name, that Whiteline markets today. They were very big in mini's about then and the tyres were Dunlop greenspots, something similar to the historic tyres used today.
  • Replies 50
well you can't argue with "facts" like that! I give up - you're right, I'm wrong! Clearly my lack of experience with prehistoric sport sedans running on conventional (ie cross ply) slicks and double wishbone suspension, or fwd minis on crossply greenspots and no real suspension, or series production 180Bs on god knows what kind of crap tyres, makes me not worthy to question your omnipotent motorsport knowledge!
I've only built, setup, and competed with an Improved Production (they haven't been called "club cars" for about a decade!) 2L Datsun 1200 with strut front end and Yokohama A032R tyres, and have a couple of mates who've done the same with 1200's and 180B's. Clearly that's not relevant! ah, hang on - that's what your mate with the 700lb front springs is "gunna" do, isn't it?
in future, have the respect to respond specifically to what you claim is wrong and why, rather than trying to tottaly discredit the person you're talking to with crap like "I've been doing this since you were in nappies" and you'll get treated with the same respect in turn. You're not talking to some pimply faced teenager, and frankly I'm not terribly impressed if one lap time set over 30 years ago is the best you can find to brag about in your long and illustrious mortorsport career...
later,
Harry
later,
Harry
Where did I try to TOTALLY DISCREDIT YOU?????????????
Go read the text before shooting your mouth off.
Go dig up a copy of a 98/99 handbook because 2E club cars are listed in it.
And specifically "corner weights have nothing to do with spring rates"
Where did I say anything about corner weight specifically, I simply said WEIGH the car or are you now suggesting a set of 1mm thick springs might be just the answer in your 2L 1200 front, or a set of 20mm might be better.
Which is the go? or is hit and miss your best plan of attack?? might get a bit expensive???
There has to be a starting point and the weight of the car is a pretty good place to start for my money, as the standard springs are designed for a prescibed RIDE and have exactly nothing to do with the cars handling charateristics.
What's your answer, go and see Mr Pedders or Whiteline and take what they recommend, take what they are trying to SELL to anyone that asks. Pedders won't even disclose their spring rates and when asking they tell you anything you want to hear even when proven wrong, as I have a set of pedders springs, got them measured and then asked and got bullsh!t for an answer. You have one of the best spring makers in Oz in Qld but I wouldn't use their recommended springs in any of my cars.
You are right when most 3J cars never see a set of scales. More fool them! go tell messrs Brock, Gibson, Johnson, Gardner etc, etc, etc about your set up method and see how you fair.
As for your improved production 2L Datsun 1200 rocket ship, with it's high tech strut suspension I think you would be hard pressed to be within 10 seconds of the flying minis of Peter Manton, Brian Foley, Lackis Manticus and others running on Xply slicks and NO REAL SUSPENSION and a miserly 1310cc & webber carbies (NO EFI). Better still try your hand against Jim McKewon in his 1600 Lotus Cortina, maybe you might get within 20 seconds of his lap times. All of these cars were Improved Production Class.
As for our prehistoric Sports Sedans, I would like to see ANY improved production car on ANY TYRE go up against the Frank Gardiner prepared Chevrolet Corvair that was driven in it's latter years by Alan Grice and subsequently BANNED by CAMS because it was just to quick. No TURBO's or EFI in the Corvair, just a FLAT 6 & carbies.
Cheers.
where did you try to discredit me?
in a lot of respects your wrong, not all, but a lot...
...going on your age, you are obviously drawing on such a massive wealth of experience...
the sarcasim is obvious, and given that you go on to talk about how much more experience you have and how fast you were, the obvious implication is I know nothing compared to you. You don't think that's an attempt to discredit?
The point I was making, and that was apparently totally lost on you, is your experience with cross ply tyres on production 180Bs over 30 years ago is totally irrelevant to today's radial DOT tyres. As is your mates experience with cross ply slicks on sport sedans with widely disparite suspension designs which require totally different geometry and double the spring rates of strut suspensions. Setup experience from these cars are totally irrelevant to setting up a strut front end club car to run on radial DOT tyres. I was not suggesting that struts are more advanced than other suspension systems or that IPRA cars are better than sport sedans. Just commenting on the relevance of your experience - we were after all talking about your mates 700lb sprung club car...
I'll take your word for what is in the 98 manual of motorsport, because I have to purchase a copy of that every year as a requirement of my CAMS licence. I guess current information isn't terribly relevant to bench racers. But Club Cars/Imp Prod have always been a 3rd catergory class since its inception. Group 2 is for sports cars. Assuming you meant 3E which is Series Production, a totally diferent category to Improved Production. What are you talking about?
oh, so from just the total weight of the car you can choose appropriate spring rates for front and rear hey? aren't you clever... And if you go to Pedders or Whiteline for advice on springs for a race car, then good luck to you! I choose spring rates primarily through experience - knowing what ballpark sort of figures will work, and then tweaking from there with feedback gained from seat of the pants feel. I'm still using the first set of springs I chose, and they are on the stiff end of the spectrum, but still well and truly under half the rate your mate is apparently running. Its not rocket science, but if you think the ball park set of figures for DOT radials on cars about the weight of a 200B is anywhere up to 700lb, I can understand why you think it is so difficult.
it was in particular reference to club level motorsport, and in direct response to you suggesting road cars should be put on scales to select their spring rates. Your V8 Supercar reference is just a smokescreen, there is simply no response required to that.
unlike you, I never made any claims about how fast I am. But since you mention it, my lap times at Morgan Park, which is reknowned as a handling circuit, are faster than the best Nc Mini in the country running on vastly superior modern radials, so pardon me if the thought of minis and lotus cortinas on 60's or 70's technology cross-plies does not set my legs atremble... btw, the lotus powered escorts and cortinas are seconds off that pace.
Bahahaaha, how can you say that harry wouldn't have heard of Warwick Park... it's still quite well known.
Just because you or your friend has been there and done that it doesnt mean that you are all-knowing. My old man (who is the same age as you) was racing GT6's and Spitfires at Mallala/AIR/Winton/Oran Park/Phillip Island/whereever in the 70's and 80's and he was very quick but I doubt he could be trusted to set a car up. Same with his friend who was running a historic Datsun Fairlady and won the Porsche Cup in 93ish, I doubt Chris could set anything up.
The only one of his friends that I would rely on is Simon Aram, but thats because he was building front running sports sedans and Formula cars for years.
Yes, you have experience and knowledge
but you're not necessarilly always right. You don't always have to jump straight on people who don't agree with you 100% and sometimes you need to check exactly what has been said... Arguing about crossply slicks when someone has been talking about street cars and street tyres is a tad pointless.
the larger the disc mass and pad area the better for repetability. its job is to absorb heat.
spring rates on most jap coil overs are way to hard. 550lbs etc
i ran 300 in the rear and 280 in the front and it was good. on jic 5 way adjustable. still no traction.:rb26 to4 440atw at 1.2bar:
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
