I have the following items for sale. All parts are from an R32 GTR (RB26DETT) unless stated otherwise.
Brand New N1 Oil Pump - SOLD
Brand New N1 Water Pump - SOLD
R34 GTR Injectors - SOLD
R32 GTR Fuel Pump - $250
Complete head including stock cams - Was 1250, Now $1000
Oil pump - SOLD
Water pump - $50
R34 GTR Sump with no diff - $200
2 x Exhaust manifolds - $200
2 x Stock dump pipes - $50
Alternator - $80
6 x R34 GTR coil packs and wiring harness - $200 (built in igniters)
6 x Std Coil packs - $200
2 x Cam covers - $200
Turbo oil & water lines - make an offer
Block - SOLD
R33 GTR Crank - SOLD
6 x Rods - SOLD
Crank pulley - SOLD
Intake plenum - SOLD
6 x Throttle bodies - SOLD
Adapter between throttles and head - Make an offer
Fuel rail and pressure regulator - SOLD
2 x RSR Stainless steel exhaust manifolds - SOLD
2 x Stock turbos - SOLD
2 x Stock AFM’s - SOLD
Trust clear cam gear cover - SOLD
Front brake callipers (4 pot) and lines - SOLD
R-SEC chipped ECU - SOLD
All prices are negotiable
All parts are located in Townsville, QLD, and can be sent anywhere at the expense of the buyer.
Contact me on 0401 136 794 or [email protected]
Cheers,
Gary.
https://www.sau.com.au/forums/topic/71673-r32-gtr-parts-for-sale/
  • Replies 53
Hi Gary;
is there any difference between R34 and R32 GTR manifolds?
Regards
The R34 ones are much newer (19,000 km) and obviously in better condition. As for the design I'll have a proper look tonight and let you know.
Hi Gary;
Regards
I had a look and although they have different numbers cast on them, they appear to be exactly the same. So I'll make the price the same for both.
Would the R34 coil packs fit into a R32 RB26 ?
The R34 coil packs will definately fit but they have built in igniters. This means that you need to modify the R32 wiring to bypass the igniter module and go straight to the coils.
I will supply the harness for the coils also.
I received a lot of responses and hopefully I have replied to everyone. Please let me know if I have missed anyone.
I have just found out that the crank is an R33 GTR crank, as it has the full length connection to the oil pump. Does anyone know how to tell if the rest of the motor was an R33? Any other differences?
I also have the wiring harness to go with the R34 coils.
Hey Mike,
Unfortunately one of my turbos died and the bits of ceramic went back up into the motor. It lost compression on 5 cylinders. I have an R34 motor in the garage waiting to go in.
Are you still in Townsville? We still have to catch up!
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
