yes, im very tempted, if its cooling down i will be there.
Ive gotta see my uncle on the weekend, hes an SS driver, and he always points out my 'rice racer'
i need a timeslip to stick in his face.
Rocko eh.
I used to live down there, dad still works down there, so ill give him a ring and see whether theres a nice breeze in by then.
  • Replies 89
Just got back from the drags, I'm kinda happy but still dissapointed with my times.
Got a few flat 14's out and a best of 13.9, but the car had shitloads in it, it was the driver that ruined it.
EVL R33 got a best of 13.4, of the runs I saw, but he may have bettered it. We were swamped by the number of STI's, all running low 13's or better.
It was a bit of a poor showing from the Skylines, with only a handful there, probably the hot weather putting people off.
The heat was unbearable as the start, and even at 9:30 was still uncomfortable. I think times may have been slightly down due to the heat and shitty track conditions, better traction on the normal road, but there are no excuses.
I've got a twin plate clutch and no matter how many ways I tried I just couldn't get a decent launch, usually lighting the tyres up through into 2nd. But if practice makes perfect then I'll be down there next Wednesday.
I must say that to all who told me that low tyre pressures work, you were dead right, and doing a burnout, with the tyres Hicks not the clutch, also helped. Other than that with top speed at 170km/hr I should have gotten a better time, so I'll be there next Wednesday early again.
I would have gotten 15 runs in, pretty good value for money if you ask me.
See'ya:burnout:
(my tyres)
Yeah, I suppose I shouldn't be too disappointed, I think I'll have a better idea next time. It will be good fun racing one another, as we should be pretty close. I had the top end power to roll most of the other Skylines and 300's and some V8's, but everybody got the jump on me big time.
Looking forward to next Wednesday already.
See'ya:burnout:
meh.. with mid to hi 13's i'd say u must be running the slow v8's most gen3's down there are atleast pulling mid 13's nowadays :P
not to mention wheel standing torana's and the like. Altho there are a fair few slow v8's there, try lining up an unasuming grey VT HBD with BBS hockmesh rims. just bolts ons and a new Torque converter, should give you a run :)
Well, sort of happy...
best of 13.6 @ 102mph, 60' of 2.00 (best of the night 1.8).
When I got a good start, I stuffed something up (read missed a gear, damn shortshifter:D ), and when I had good top end runs I bogged down..
But practice makes perfect so I'll be down there again don't you worry. Had a great time, met Paul and a couple of other skyline owners.
Brett
Don't get me wrong, some of the V8 guys have awesome cars, like the totally bombed torana's, but I was sursprised that I managed to run down some of the others, I expected more top end from them. I think one of the torana's managed to just get into the 9's.
It was a great night, and nice to see EVL R33's new ride, even though there was one almost identical down there. I hope conditions are a bit more favorable next week, and they prepare the track better, but I'll be there trying to improve my times.
See'ya:burnout:
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
