Doc's Newest Toy!!!!!!! mwahahaha
That's right..... new toy on the cards......
180sx as per attachment (Pickup this weekend)
T3/4 - 0.7 split pulse T3 housing machined for 60mm 11 blade wheel, new core, T04B front cover machined for T04E wheel (Delivered Thursday)
Nismo Twin Plate (Pick Up Friday)
VOLK 17x8 and 17x9 Rims with full R33 5 Stud Conversion (See second attachment)
FMIC, 600HP Pump, 550cc Injectors, & 300ZX AFM (To be purchased Jan)
Full VERTEX Widebody Body Kit (Purchase Jan)
Dr_Drift Custom RB20ECU with VCT controller
:bahaha: :burnout:
https://www.sau.com.au/forums/topic/7169-docs-newest-toy-mwahahaha/
Originally posted by predator666
scary...dr drift has a real driftable car... saw that video of the old R32 GTS-T and was quite impressed :burnout:  What happened to that anyway?
its not his first 180...
hey dr.... when u get back??
Boxhead - Through an importer mate.... I'll be marketing them as soon as each mold is available... will keep ya posted with any 32 stuff.
Predator666 - All cars are driftable.... Some more than others.... Sold the R32 cause there wasn't enough head room with sunroof and helmet on. Cheers for the compliment... maybe you'll see the full video and not just that dodgy burnout clip......
Doxx - As above
Inark - HERE Bro - I'm Staying Now.... Back in town on wednesday... My old 180 was pretty nice too... but now where near the rwkw this monster will have mwahahah
Ice180 - Will keep ya posted with pix when available.... Thanks for the twin plate by the way.....
Doc.
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
