Hi all, firstly dont want this to become a bitchy battle!!
My car is r32 4door (rb20) with following mods, apexi FMIC, Apexi Power FC, HKS oil cooler and relocation kit, full turbo back exhaust, cold air induction and pod, r33 turbo (s2), full HKS suspesion, clutch, diff, front and back struts, floor brace etc etc, you have the idea. Its a great car and planning to keep for next 10 years, yes 10 years! but car is already tied from hard life in japan and now from me on track. It is also my daily drive
I have done heaps of research over the last year and know the pros and cons of both just want experience to make the best call for the long term plan. Due to funds doubt I will have enough to get a turbo so rb25 will have to do for now. but want car to run reliable 250rwkw (with a new turbo im guessing)
1. rb30 bottom with rb25 head.
2. rebuild rb20 to rb24 and do some extensive head work including rb25 valves if they fit.
Both will have forged bottom ends. and want to use my power fc (r32)
I guess it comes down to this, if you were spending this sort of money with a 10 year out look will one end up being more reliable, cheaper, enjoyable than the other.
cheers
Cam
https://www.sau.com.au/forums/topic/71789-rb30-or-rebuild-rb24/
i am in the exact same boat...
sorry to semi-hijack...
but i have a 32 4 door... which is getting a fresh rb20 with 1.2mm headgasket, power fc, hks t04e external gate kit, hks twin plate, rb25 gbox, trust front mount and z32 etc etc fitted...
i know the rb20 wont take the t04e for very long - especially considering its going to be drifted...
i was thinking of purchasing an rb20 short motor (block/head) so i can strip it down and get it rebuilt/stroked with forgies etc... question is... im unsure as to what has to be done and used...
which crank would i use? rods?
- adz
- adz
Rb25 crank and rods make it a 2.3Lt
rb26 crank and rods make it a 2.4Lt
I think this was what i found when i was looking at the same options....
P.S. a short motor is just the block, a long motor is the head and block together...
When I added it up for myself (and several others since) the RB30DET was cheaper for the same power output. For example a completely standard RB30 bottom end will get you 280 rwkw. I built one that has been going strong for nearly 5 years now at that power level and it cost less than $1200 for the bottom end, rebuilt and balanced with new seals, gaskets, rings and bearings. You can't do an RB20/23/24 with that much power for twice that much. Plus it will have to run higher boost and rev to higher rpm which will shorten its life.
Easiest decision ever, I went for the RB31DET and I already had the RB20 block, RB20 cylinder head, RB26 crank, RB26 rods and 4AGZE pistons :D
Cool no wories, makes sence. So do you rebuild with forgies for that price.. Is it best to by a rb30 in good condition and not rebuild it or buy on price with expectation of wanting/needing to give it some attention. Where is the best place to get rb30 bottom end from.
No forgies, it was a STANDARD bottom end, that means standard RB30E pistons.
Any Holden wrecker will have an RB30 or 2 in stock, just don't mention "Skyline" they will double the price. Says it is for an "old VL" or something. Pick the closest one to you as they weigh 100 kgs or so and you don't want them freighted around, they get dropped. I would always rebuild an RB30, they are 19 years old after all. :D
Exactly what I thought possible and what I want to do albeit with RB26 bits (even experimented with a quote from GEM for $1600 assembled, extra for balancing and anything else I want ).
SK I assume you buttoned it up yourself at that price? Would forged pistons allow you to stretch to a safe 350 rwkw or so? What rpm limit do you observe? Did you ceramic coat the pistons to overcome the absence of oil squirters?
Regards
Regards
Yes, I assembled it myself. The problem with a standard RB30E is everything (except the crank and block) has a ~475 bhp limit. So replacing pistons alone does very little for increasing the safe power limit. You need conrods, head studs, main bearing studs, decent bearings, oil pump etc etc So I either have a 475 bhp RB30 or a 750 bhp capable RB31, anything in between costs me the same anyway.
We have added block mounted oil squirters (it's a bitch of a job) and ceramic coated the pistons with conrod oil squirters. Both methods seem to work equally well at the power levels we run. Cost wise, go the ceramic coated piston crowns and conrod based oil squirters.
Hope that makes sense:cheers:
Thanks SK,
Is that 475hp x .75 = 350kw at the fly? Allowing for losses atw that would equate to the 280 rwkw you mentioned.
Your comment that 'anything over 475 hp costs the same' makes sense. But assuming the $ for a bullet proof engine aren't available and if a stock RB26 can make 280rwkw safely, why go to an RB26/30 except for a bit more torque (and a fair bit more messing about to install it). Is it the cost? What am I missing?
What rpm limit do you observe for the stocker bottom end?
Regards
massive fan of rb30s
whacked rb25 head on my rb30 bottom end in my 4door oz 31
i was always impressed with the torque of the rb30e. but the twin cam combo has me pissing my pants. it's frickin brilliant. tdo6-20g. front mount all the usual shit. usual rb25 afm. crappy plum back bov. not running well at the moment. whacking in q45 afm. better plum back bov. boost controller (provided thew 2door below sells sometime soon) then will try and give it a squirt on the dyno tuner @ 15psi
at the moment, runs on 8psi and squeezed out 226 at the rears.
rb30 all the way mate
thanks 88, picture tells a thousand words. 226 ATW on 8 psi is excellent. stock bottom end?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
