Hey All, time to move on to a new car.
1989 White R32 GTR
78xxx kms showing on a Nismo 260km/h Dash
M's intake for K&N filters
Nismo 3" Stainless Exhuast.. CAT Back
IMPUL Chipped Standard ECU
Twin Blitz BOVS
Full service just taken place.. oil filters etc
Vault Kaotic 18*9.5 with 265/35/18 tyres all around *3000kms old*
Just resprayed std white
Aftermarket BX2 Sideskirts
Custom Veilside S14 Pods to fit GTR
Interior Spotless besides 1 10c Piece size Cigarette burn on back seat...
Dark window tinting
Cross Drilled front and rear discs
Lowered
Aftermarket clutch.. not sure what type
Blitz Boost Guage
Regassed Aircon! not many new imports have this done!
Cars been compression tested all 100%..
Im wanting $23990 for everything..
http://www.carsales.com.au/pls/csauth/!cs_...rch_distance=25
Ive just installed a $2500 sound system.. well this is optional and available for $1500 extra.. bargain but i cant be bothered taking it out after 3 days were spent installing it..
https://www.sau.com.au/forums/topic/71887-fs-clean-r32-gtr-gtrush/
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
