Hi all,
I recently went to an electronics and computers expo in Sydney called Cebit (anyone else go?) and I saw a stand for an Aussie company called Voxson (www.voxson.com.au). They had a car MP3 player on show which also played CDs. The killer bit about it was the price - $259 - $299. It's going to be released in the next 2 or 3 weeks apparently.
Now, every other MP3 player I've seen for cars has been well over $500, some even over $1000. So, is this some sort of wonder head unit or am I missing something vital here. I really can't see how these other units can be so much more expensive.
Cheers,
Mic
BTW there's no info on the web page yet, it'll be up soon they said.
https://www.sau.com.au/forums/topic/719-mp3-players/
if i remember correctly, voxson used to be a shitty b-grade electronics company that made crap stuff that you would buy if you knew no better.
THATS if i remember correctly - which is highly improbable.
that is pretty cheap too, i was looking at a nice kenwood unit for about $900/
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-16326
I've never even heard of them. I suppose I'll be a guinea pig and try it out. I'll tell everyone here what it's like so they can either get one or be warned about it.
What was the model of the Kenwood you were looking at? I'd like to compare features when this one does come out.
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-16340
Voxson used to make discmans and stuff like that.
They distributed out of Brisbane.
Cheap no frills stuff. Pretty good quality but I haven't seen anything from them for a year or so.
It could be something to make them a big name, or maybe there just tryin to make money by jumping on the bandwagon. I spose it doesn't matter too much at that price though?
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-17423
Go the AIWA CDC-MP32!!! Wholesome Sony goodness (one up from shit) for $400 bucks. The Voxson one sounds like the CD-MP3 players you find at Northrocks Markets... ahh back in the day when i used to live in syd (like feb '02)... they do the job but skip like crazy, and they only play selected formats (VBR etc) stored in specific file structures.
My Headunit
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-17474
Personally I like the highend JVC MP3 unit, the Alpine is quite nice and the sound quality is comparable if not slightly better than the JVC, but it costs a lot more. Well over $1k everywhere I have seen.
I did see a kenwood 9020R MP3 headunit in Brisbane car sound today and it looks really shmick, and I generally don't like kenwood gear so that is high praise. No idea what it sounds like though.
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-22616
Guest Krystian_w
Hmm...
There's also the MP Zoo, don't know how it works exactly but it actually plugs into a Hard disk and plays MP3's straight off it. That means you can fit a couple of hundred CD's worth of music on the HDD...
Don't know much about stereo's but thought you might want to take a look...
If it helps I saw it at Brisbane Car Sound for about $800
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-25203
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
