Just Some stuff needing to clear
- R33 GTST Fuel Pump (Great upgrade for S13/14 etc) = $70.00
- R33 Stock Cooler = Make an Offer
- R33 TypeM rear pods (EC) = SOLD
- R33 HKB Boss Kit (GTR) = $20.00
- R33 GTST TEIN Coilovers (Height adjustable)(GC)(No leaks) = SOLD
- R33 FibreGlass S1 Vented bonnet (Slightly damaged)(Easy Fix) = SOLD
- Hybrid Cooler (Limited edition GT Spec Bar and Plate)(Wchrome piping)(Completekit)(BrandNew) = $850.00
- S15 custom built 3" dump pipe (GC) = $125.00
- S15 Cat back with chrome cannon (GC) = $150.00
- S15 stock front bar (Red)(GC) = $145.00ono
- S15 stock rear bar (Red)(GC) = $175.00ono
- S15 factory drivers tail light (EC) = $150.00
- Apexi BOV with piping (GC)(Sits next to cooler) = $175.00ono (plus ur stock pipe)
- 180SX SR stock front bar (Purple)(EC) = SOLD
- 180SX Stock rear bar (Purple)(GC) = $100.00ono
- 17" Concept 9 Wheels with GoodYear tyres (Shaddow Chromes)(EC)(215@front, 235@rear)(Multi-fit 4 stud) = $1000.00
- AutoGauge gauges (BrandNew)(Smoked Series. Looks like Defi black faced gauges):
Digital Air/Fuel ratio = $65.00
Boost = $60.00
Oil Pressure = $65.00
Oil Temp = $65.00
Water Temp = SOLD
Vaccum = SOLD
- Sports Steering Wheel (GC)(Old School style) = $50.00ono
- Triple gauges holder for din slot (BrandNew) = $30.00
- 5" AutoGauge Monster Tacho with external shift light (BrandNew in Box)(Silver Faced) = $150.00
https://www.sau.com.au/forums/topic/72062-~clearingout~/
  • Replies 52
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
