Looking good Mick...  Been a long time coming...  :)
For sure Adrian, 20 months and i stil have stuff to do, parts to fit, i havent even polished it or blackened the tyres yet.... And its not getting done today either, lol.
Been awhile since ive seen you, im in the market for a rolla(or aus86), you selling?
https://www.sau.com.au/forums/topic/72166-northside/#findComment-1328731
Heh I was begining to wonder if it even existed!  Worth the wait by the looks...
Yeah I am selling the Rolla actually...  It's a bit messy inside and out, but shit it goes hard...  MSN me if ya want...
Heh im suprised you remember whatever i said to you about it however long ago, its been painful watching you guys drive yours while i have only been working on mine!!! tho i like it i much prefer to be driving it :)
https://www.sau.com.au/forums/topic/72166-northside/#findComment-1328759
hmm I'm after those factory front bumper like the ones you got (not cut up of course) :)
Look close, i have cut it but ive also built it back up so it doesnt look all hacked and 5c like
Mud: Cheers mate i think its getting there still got plenty on my mind still havent rang nissan for the bootlid lip. I am gong to make the GTR spolier part time when ig get that :D
https://www.sau.com.au/forums/topic/72166-northside/#findComment-1328807
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
